CPT 6.1.1 ASA5505 NAT from a subnet different from the connected interface
gustindav
As part as an exercice I'm doing by myself, I'm trying to figure out if it possible for a ASA5505 in Cisco Packet Tracer to NAT trafic coming from a different subnet than the interface it is received on.
My host is configured with the address 192.168.4.1/26 and goes through a router (1841). The router is its gateway with the address 192.168.4.62. I'm trying to ping the IP 87.91.134.22 that I've set on a Laptop in the Outside VLAN of my ASA5505. The 1841 is connected to the ASA using the address 172.16.0.1/30 in the inside VLAN (int vlan inside has 172.16.0.2/30).
If I configure an object network for the inside like so :
object network inside-subnet
subnet 192.168.4.0 255.255.255.192
nat (inside,outside) dynamic interface
My packet isn't translated. 87.91.134.22 receives the packet with a 192.168.4.1 as the source IP.
It is because the interface connected to the ASA doesn't match the subnet ?
If I configure an object network for my dmz, which uses a 172.16.1.1/29 network (server has .1 and ASA's vlan dmz int has .6), like so :
object network dmz-subnet
subnet 172.16.1.0 255.255.255.248
nat (dmz,outside) dynamic interface
I can see using the simulation mode that my packet is translated just fine. I even get the ping back when using an ACL permitting any icmp trafic on the outside interface.
My end goal is to have a bunch of VLANs (all being 192.168.x.x/26 subnets) going through the router, being routed to the ASA (using a 172.16.0.0/30 subnet) and then translated to the Laptop representing my Internet access.
What do I miss ? What did I do wrong ? What can I do to make it work ? Is it even possible ?
Any help would be much appreciated.
Thank you,
David
The NAT should work. If the outside laptop sees the internal IP I would think that it is related to packet-tracer.
What your config is missing: You need a route on the ASA for the internal network pointing to your router:
route inside 192.168.4.0 255.255.255.192 172.16.0.1
And for the ICMP return-traffic, it's better to enable ICMP-inspection in MPF instead of allowing it in the ACL.
Hello Karsten,
Thank you for your answer. I've thought about setting a route for the inside but since my packet wasn't translated it felt like cheating and avoiding the real issue.
I guess it might be a CPT limitation.
Follow up question : if my vlans are all 192.168.x.x/26, can I use 192.168.0.0 255.255.0.0 in my network object?
Again, thank you for taking the time to answer me,
David
I mean "could I, in a situation where my packers were translated?"
For sure! If you can, then summarize all your internal networks to have less routes in your config.
