Does ASR 9000/IOS XR support Remote monitering(RMON)?
yuhsianghh
I have checked the Catalyst switch and Nexus 7000 have the RMON function. But I can't  find any specs for ASR 9000 supporting RMON. Does it have the same function for RMON in a deffresnt name or RMON just doesn't support in IOS XR? Is there any documents showing IOS xXR(ASR9000) have RMON specs?
smailmilak
Level 4
Level 4
have you already found the answer for your question?
If not, You should ask this in the XR section on this forum.
