CPU high utilization due to interrupts
johnywalker
I have and issue in our network that router cpu usage showing as high.
When i issue "show process cpu sorted" it giving the output
CPU utilization for five seconds: 87%/73%; one minute: 78%; five minutes: 69%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 121   338610360   229817079       1473  3.59%  2.43%  2.28%   0 IP Input
 349   424138972   252919405       1676  3.03%  1.76%  1.83%   0 IP-EIGRP: PDM
 319    25626784      423522      60509  1.83%  0.42%  0.40%   0 L2TP mgmt daemon
 197    24295708   612702392         39  0.79%  1.14%  1.28%   0 HQF Shaper Backg
 336    71451564    11152148       6406  0.63%  0.51%  0.49%   0 DNS Server Input
 354        7700         707      10891  0.55%  0.67%  0.49% 516 Virtual Exec
 351    73787092   141822344        520  0.55%  0.38%  0.39%   0 IP-EIGRP: HELLO
 335    55353756    14943600       3704  0.39%  0.34%  0.33%   0 DNS Server
 328    11407336    94673937        120  0.31%  0.33%  0.34%   0 PPP manager
  19    15587772    12813254       1216  0.31%  0.29%  0.29%   0 ARP Input
   2     2076148      640461       3241  0.23%  0.35%  0.21%   0 Load Meter
 118    11051532    12211664        904  0.23%  0.20%  0.18%   0 ADJ resolve proc
  41     9637756     3197987       3013  0.23%  0.27%  0.25%   0 Per-Second Jobs
 145    25610012     5329013       4805  0.15%  0.08%  0.09%   0 IP RIB Update
 329     6482628    94672351         68  0.15%  0.15%  0.15%   0 PPP Events
 321     1519860     6158214        246  0.07%  0.05%  0.06%   0 IP NAT Ager
 343     1026372     2613651        392  0.07%  0.04%  0.01%   0 NAT MIB Helper
 326     1242604    24193482         51  0.07%  0.03%  0.02%   0 PPPoE Background
 153     4248308     4696498        904  0.07%  0.12%  0.15%   0 CEF: IPv4 proces
  96     2639052     1278400       2064  0.07%  0.07%  0.07%   0 DSL State Machin
 270      208452     3196936         65  0.07%  0.00%  0.00%   0 Crypto Device Up
  64     1032652    12686268         81  0.07%  0.02%  0.01%   0 Netclock Backgro
 105      191480     3170616         60  0.07%  0.00%  0.00%   0 linktest
 208      447200     6148645         72  0.07%  0.01%  0.00%   0 CCE DP URLF cach
 176      270304     3170565         85  0.07%  0.00%  0.00%   0 ATMSIG Timer
  25           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  24           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  23           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  26           4           2       2000  0.00%  0.00%  0.00%   0 Entity MIB API
  27         980        2581        379  0.00%  0.00%  0.00%   0 EEM ED Syslog
  28           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  32      243984     3196903         76  0.00%  0.00%  0.00%   0 GraphIt
  33           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  22           0           2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  35           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  29           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  30           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  21           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  39        1212        4571        265  0.00%  0.00%  0.00%   0 Logger
  40      265464     3170551         83  0.00%  0.00%  0.00%   0 TTY Background
  31           0           2          0  0.00%  0.00%  0.00%   0 SMART
  34           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  43          24          11       2181  0.00%  0.00%  0.00%   0 IF-MGR control p
  44           0          21          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  45           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  46           0           1          0  0.00%  0.00%  0.00%   0 IKE HA Mgr
  47           0           1          0  0.00%  0.00%  0.00%   0 IPSEC HA Mgr
  48           4           4       1000  0.00%  0.00%  0.00%   0 rf task
  36           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
........ output omitted..
show processes cpu | inc five
CPU utilization for five seconds: 98%/88%; one minute: 86%; five minutes: 73%
The version used in the router is Version 12.4(24)T2.
EIGRP, DMVPN, Netflow also configured in this router.
Is it a IOS bug or any other issue.. ??
I am waiting for anyone to give an answer.
Sijoy
7 Replies 7
Leo Laohoo
Too many garbage with your output.  Can you post the output to the command "sh proc cpu sort | ex 0.00"?
Go to the Feature Navigator and look for IOS compatible in the "M" train.
I appreciate Leo's point that there are a lot of entries that are not using CPU cycles (have 0.00 entries) but since the output is sorted it is not difficult to ignore those entries.
The output does show a pretty busy CPU (87%/73% and 98%/88%) but most of the effort is doing Interrupt based forwarding of traffic, which is sort of confirmed by the fact the the most busy process is IP INput. There is between 10% and 14% process based activity. You might use this link to investigate possible causes of high interrupt levels
http://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/41120-highcpu-interrupts.html#causes
Rick
Rick
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Just to add to Rick's post, your interrupt CPU load is also high, which might just be due to "normal" packet forwarding for the router.  What exact model router is this and what's the aggregate traffic volume that corresponds to this CPU usage?
Hi all thanks for your comments.
It is a 2811 router.
DMVPN, EIGRP,Netflow are running on this router. There are around 95 users connected below this router.
CEF is enabled globally and it is working as packet switching.
I did CPU profile for five minutes for checking the CPU high utilization.
please find the attached.
If anyone can give me a solution it would be appreciated.
Disclaimer
Posting
Again, what's your aggregate bandwidth being forwarded?  From my experience, a 2811 tops out at about 40 Mbps, aggregate.  Normally, I wouldn't recommend such a router for more than 10 Mbps (duplex).  I believe I recall Cisco recommends a 2811 for only a pair of T1/E1s.
Any enabled features, beyond packet forwarding, will add to the CPU load.  How much depends on the feature and how it's being used.
Of those you mention, might your DMVPN be fragmenting packets?  This can be contributor to much additional CPU loading.
When i check show version DRAM and flash size showing as 256\64.
But the recommended for the same version of IOS is 256\128.
IOS installed here is, flash:c2800nm-advipservicesk9-mz.124-24.T2.bin
and also flash memory free space is around 1.5 MB .
This also will affect high CPU utilization or not ?
Sijoy
Disclaimer
Posting
Recommended flash insures you have sufficient space for the IOS image and perhaps some crash files.  Being low on it doesn't impact performance.
Recommend RAM insures you have sufficient space to run your IOS version in a "normal" environment.  Some features (e.g. Netflow) will use additional RAM, and if you run short, can cause problems. Some of the later IOS images support "graphing" memory usage, like CPU usage.  Don't recall whether you IOS version does.
Probably neither is a contributor to your high CPU.
