CPU Performance issue
knaik99
please share commands which are helpful for checking CPU performance in 9000 series switches,ISR,ASR & Viptela EDGE
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/15095-highcpu.html
 M.
show processes cpu
I think all IOS ,XR,XE are support this command
this command is basic to check the CPU utilize BUT
there are many keyword you can add and it different from one platform to other
balaji.bandi
You should rely on your NMS that is easy way to graph using SNMP, if you required more analysis in realtime you can go to CLI(show command help you based on the product and verison of code running)
BB
