CPU Utilisation high on Cisco 2900 series Router
sreeraj.murali
Level 3
Level 3
I am having the Cisco 2900 series Router, continuosly peaking the CPU utilisation. The Router running GRE Site to Site tunnel(not passing traffic at the moment, as its a backup connectivity) and is passing the office Internet traffic. The Router is continuosly peaking the CPU utilisation. I am attaching the show tech. Please check and comment.
Thanks & Regards
Sreeraj
5 Replies 5
Mark Malone
You should capture the cpu as its spiking so you can see exactly what process is causing the issue
Your show tech came back clean , no issues in the cli analyzer , cpu is low at the time it was taken
all it gave back was informational no critical issues
Restrict SNMP community access with ACL as a security best practice
SNMP is enabled but not running version 3, which is a security best practice
Service password encryption disabled causing cleartext passwords to be saved in the configuration
IOS Context Based Access Control Feature Information
IP Source Routing is enabled, which is a deviation from the router security hardening best practices
PAD (packet assembler/disassembler) service is enabled, which is a deviation from the router security hardening best practices
MOP (Maintenance Operations Protocol) Service is enabled, which is a deviation from the router security hardening best practices
IP Bootp Server is enabled, which is a deviation from the router security hardening best practices
Found missing router security best practices
Improve the Security Posture of the Device by Disabling Telnet
Evaluation period left
The data from this device was evaluated against 992 different diagnostic checks.
This script should capture the high cpu when it reaches over 70% and put it in flash
event manager applet High_CPU
    event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.4.1 get-type exact entry-op ge entry-val "70" exit-time 10 poll-interval 5
    action 0.1 syslog msg "CPU Utilization is high"
    action 0.2 cli command "enable"
    action 0.4 cli command "show log | append flash:CPU_Profile.txt"
    action 0.5 cli command "show process cpu sorted | append flash:CPU_Profile.txt"
    action 0.6 cli command "show interfaces | append flash:CPU_Profile.txt"
    action 0.7 cli command " show ip cef switching stat | append flash:CPU_Profile.txt"
    action 0.8 cli command " show ip traffic | append flash:CPU_Profile.txt"
    action 0.9 cli command " show int switching | append flash:CPU_Profile.txt"
    action 1.0 cli command "no event manager applet High_CPU"
    action 1.1 cli command "end"
Marcio Ciano
Hi Sreeraj. I had similar issue when the traffic over the GRE tunnel reaches 8M or above. I reserched and found out that this is a limitation bandwidth on GRE tunnel. As a workaround to avoid high CPU I put a rate-limit in 8M. HTH Marcio Ciano
Marcio, could you provide any links to the information your research uncovered that further describes a 2900 tunnel running at more than 8 Mbps causes high CPU?
Hi Joseph, I found the information on links below, not exactly related to 2900 series, but for my case (2911 and 1941) it seems happen the same. https://supportforums.cisco.com/t5/wan-routing-and-switching/gre-bandwidth-restriction/td-p/2682012 https://supportforums.cisco.com/t5/wan-routing-and-switching/gre-tunnel-max-bandwidth/td-p/1400841
Thanks.
