How to config router to handle two eigrp AS without vrf
Ibrahim Jamil
Level 6
Level 6
Hello Freinds
can i config router to handle two eigrp AS without vrf like below
router eigrp TEST
address-family ipv4 unicast autonomus-system 10
network 10.10.10.0 0.0.0.255
address-family ipv4 unicast autonomus-system 20
network 20.20.20.0 0.0.0.255
6 Replies 6
Hello
@Ibrahim Jamil wrote:
Hello Freinds
router eigrp TEST
My understanding is you will require two different named eigrp named stanza's
router eigrp TEST1
topology base
exit-af-topology
router eigrp TEST2
topology base
exit-af-topology
res
Paul
Kind Regards
Paul
Hello Paul
thanks for reply
is it possible like below: aka in 1 named AS but with diffrent ASs
router eigrp TEST
thanks
Hello
No it isn’t
Res
Paul
Kind Regards
Paul
thanks paul
n.bokhar1
short answer yes you can
the reason we have named eigrp mode to run everything eigrp in one instance
Hello
If you the mean everything like ivp4/6 unicast/multcast in the same address family and ASN then that's as I understand it but you cannot have same address family in deferring ASN without VRF
Example:
you can have:
address-family ipv4 unicast autonomous-system 100
address-family ipv6 unicast autonomous-system 200
address-family ipv4 unicast vrf STAN autonomous-system 200
but not..
address-family ipv4 unicast autonomous-system 200
res
Paul
Kind Regards
Paul
