CPU Utilization is High
HI team,
         we are getting high cpu utilization on 2901 router but same configuration while switchover to cisco 2911 router is working fine. Could you confirm any differences are there at throughput level or any other reasons are there Pls suggest on this.
------------------ show version ------------------
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.7(3)M7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Tue 01-Sep-20 15:17 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
CNNW0000001 uptime is 5 weeks, 6 days, 23 hours, 47 minutes
System restarted at 15:18:33 IST Mon Mar 15 2021
System image file is "flash:c2900-universalk9-mz.SPA.157-3.M7.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FGL1605220T
3 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 terminal line
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2901/K9 FGL1605220T
Suite License Information for Module:'c2900'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
datak9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
------------------ show interfaces ------------------
Embedded-Service-Engine0/0 is administratively down, line protocol is down
Hardware is Embedded Service Engine, address is 0000.0000.0000 (bia 0000.0000.0000)
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Last input never, output never, output hang never
Input queue: 0/64/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier
GigabitEthernet0/0 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is f0f7.5545.d820 (bia f0f7.5545.d820)
Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
Internet address is 10.9.24.1/24
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 3/255, rxload 3/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive not set
Full Duplex, 1Gbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/12/16136 (size/max/drops/flushes); Total output drops: 151
5 minute input rate 14885000 bits/sec, 2891 packets/sec
5 minute output rate 13423000 bits/sec, 2884 packets/sec
1746383774 packets input, 1040924190 bytes, 28 no buffer
Received 10612175 broadcasts (0 IP multicasts)
0 runts, 0 giants, 11 throttles
1624462 input errors, 0 CRC, 0 frame, 1624462 overrun, 0 ignored
0 watchdog, 269245 multicast, 0 pause input
1755078618 packets output, 3745533937 bytes, 0 underruns
272259 unknown protocol drops
4 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/0.3 is up, line protocol is up
Internet address is 10.9.124.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 3.
GigabitEthernet0/0.4 is up, line protocol is up
Internet address is 10.11.24.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 4.
GigabitEthernet0/1 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is f0f7.5545.d821 (bia f0f7.5545.d821)
Internet address is 10.43.191.57/30
MTU 1500 bytes, BW 4096 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 130/255, rxload 20/255
Full Duplex, 100Mbps, media type is RJ45
output flow-control is XON, input flow-control is XON
Last clearing of "show interface" counters 5w6d
Input queue: 1/75/0/2 (size/max/drops/flushes); Total output drops: 2060277
Queueing strategy: Class-based queueing
Output queue: 55/1000/2049355 (size/max total/drops)
5 minute input rate 329000 bits/sec, 264 packets/sec
5 minute output rate 2096000 bits/sec, 421 packets/sec
219825901 packets input, 261388934 bytes, 0 no buffer
Received 389 broadcasts (0 IP multicasts)
29565 input errors, 29562 CRC, 5941 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
217050546 packets output, 3277816971 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
182 lost carrier, 0 no carrier, 0 pause output
Serial0/0/0 is down, line protocol is down
Hardware is WIC MBRD Serial
MTU 1500 bytes, BW 2048 Kbit/sec, DLY 20000 usec,
Encapsulation PPP, LCP Closed, loopback not set
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 carrier transitions
DCD=down DSR=up DTR=down RTS=down CTS=up
Serial0/0/1 is administratively down, line protocol is down
MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, loopback not set
0 output errors, 0 collisions, 3 interface resets
DCD=down DSR=down DTR=down RTS=down CTS=down
GigabitEthernet0/3/0 is up, line protocol is up
Hardware is EHWIC-1GE-SFP-CU, address is f0f7.5545.d840 (bia f0f7.5545.d840)
Internet address is 172.19.2.97/30
reliability 255/255, txload 18/255, rxload 35/255
Input queue: 0/75/36/4552 (size/max/drops/flushes); Total output drops: 55716
5 minute input rate 566000 bits/sec, 340 packets/sec
5 minute output rate 292000 bits/sec, 198 packets/sec
340606648 packets input, 3219461145 bytes, 0 no buffer
Received 4956935 broadcasts (0 IP multicasts)
0 runts, 0 giants, 25 throttles
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
327375249 packets output, 1478642140 bytes, 0 underruns
8443 unknown protocol drops
7 lost carrier, 0 no carrier, 0 pause output
------------------ show process cpu history ------------------
CNNW0000001 03:05:54 PM Monday Apr 26 2021 IST
411111111111111111111111111111111111111112222222222222227777
188888777774444477777888885555555555888883333355555444446666
100
90
80 ****
70 ****
60 ****
50 ****
40 * ****
30 * ***** ****
20 *********** ********************************************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
729118592282282833437122722192294292261292381893811727261113
683877628850972648632911233913520754027411268206056464099687
100 *
90 * * * * * * * * * * * *
80 * * * * * * * * * * * * ** *
70 * * * * * * * * * * * * * * ** * * * *
60 * * *** * * * * * * * * * * * ** * * * *
50 * * *** * * * * * * * * * * * * ** * * * *
40 * # *** * * * ** * * * ** * * # * **** * * * *
30 #*# #*#**# *# #*##*# # # *#**# # # ** ##** *** * *
20 ###**#################################*#####*####**###*#***#
10 ############################################################
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
99999981 111 1 11111 1 1 1 1889999989998 1 11 111189889
456354218810080998880100094799997988907198072324159443790902820317099344
100 ** * *
90 ****** * ********** *****
80 ******* ************ *****
70 ******* ************ *****
60 ******* ************ *****
50 ******* ************ *****
40 ******* ************ *****
30 ******* ************ *****
20 ######* ****#*##*##* ***##
10 #######*************************************###########***********####
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
------------------ show process memory ------------------
Processor Pool Total: 274480668 Used: 95630260 Free: 178850408
I/O Pool Total: 46137344 Used: 17797376 Free: 28339968
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 173368684 94097120 69809692 974 116276052 *Init*
0 0 12576 34286464 12576 12 12 *Sched*
0 0 444466224 436926136 854676 991 983 *Dead*
0 0 0 0 591664 0 0 *MallocLite*
1 0 7928864 2100144 5906844 0 0 Chunk Manager
2 0 240 240 4264 0 0 Load Meter
3 0 29172 820 54300 0 0 LICENSE AGENT
4 0 65588 0 90852 0 0 EDDRI_MAIN
5 0 0 0 7264 0 0 RO Notify Timers
6 0 3360 240 10384 0 0 Check heaps
7 0 4082804328 4083497728 225476 49 0 Pool Manager
8 0 0 0 7264 0 0 DiscardQ Backgro
9 0 240 240 7264 0 0 Timers
10 0 0 0 4264 0 0 WATCH_AFS
11 0 0 0 13264 0 0 License Client N
12 0 0 0 7264 0 0 Image License br
13 0 1717935728 1717936460 7264 0 0 Licensing Auto U
14 0 182096 16996 181308 0 0 RF Slave Main Th
15 0 0 0 4264 0 0 RMI RM Notify Wa
16 0 240 240 7264 0 0 Environmental mo
17 0 0 0 7264 0 0 IPC Event Notifi
18 0 0 0 7264 0 0 IPC Dynamic Cach
19 0 0 0 7264 0 0 IPC Session Serv
20 0 0 0 7264 0 0 IPC Zone Manager
21 0 0 0 7264 0 0 IPC Periodic Tim
22 0 0 0 7264 0 0 IPC Deferred Por
23 0 0 0 7264 0 0 IPC Process leve
24 0 2104 0 9368 0 0 IPC Seat Manager
25 0 0 0 7264 0 0 IPC Check Queue
26 0 0 0 7264 0 0 IPC Seat RX Cont
27 0 0 0 7264 0 0 IPC Seat TX Cont
28 0 0 0 7264 0 0 IPC Keep Alive M
29 0 0 0 7264 0 0 IPC Loadometer
30 0 0 0 7264 0 0 IPC Session Deta
31 0 0 0 25264 0 0 Crash writer
32 0 380 0 7644 0 0 Exception contro
34 0 0 0 7264 0 0 IFS Agent Manage
35 0 1568968 1483580 45836 5428675 5428674 ARP Input
36 0 16001516 15893440 7264 8877 8877 ARP Background
37 0 240 240 7264 0 0 ATM Idle Timer
38 0 0 0 7264 0 0 ATM ASYNC PROC
39 0 0 0 7264 0 0 CEF MIB API
40 0 0 0 7264 0 0 AAA_SERVER_DEADT
41 0 0 0 13264 0 0 Policy Manager
42 0 240 240 7264 0 0 DDR Timers
43 0 22328 15092 29512 47 47 Entity MIB API
44 0 996 996 7264 0 0 PrstVbl
45 0 240 240 7264 0 0 Serial Backgroun
46 0 0 0 13264 0 0 License IPC stat
47 0 0 0 13264 0 0 License IPC serv
48 0 8524 8600 7264 2 2 SMART
49 0 1688 0 8952 0 0 RF SCTPthread
50 0 1688 0 8952 0 0 CHKPT RG SCTPthr
51 0 0 0 7264 0 0 ARP Snoop
52 0 240 240 7264 0 0 GraphIt
53 0 240 240 13264 0 0 Dialer event
54 0 0 0 7264 0 0 SERIAL A'detect
55 0 240 240 13264 0 0 XML Proxy Client
56 0 244396 258764 7804 0 0 crypto sw pk pro
57 0 0 0 7264 0 0 Critical Bkgnd
58 0 1546904 523308 31300 726372 726372 Net Background
59 0 1520 1520 13264 0 0 IDB Work
60 0 240 240 13264 12916 12916 Logger
61 0 410176 8300 7264 0 0 TTY Background
62 388 1475592 439800 1060788 256 256 Virtual Exec
63 0 66872 0 14308 0 0 CTS CORE
64 0 1044 14972 14068 0 0 SXP CORE
65 0 201376 0 142812 0 0 IF-MGR control p
66 0 0 0 7264 0 0 IF-MGR event pro
67 0 0 0 4264 0 0 Inode Table Dest
68 0 0 0 7264 0 0 cpf_msg_holdq_pr
69 0 0 0 7264 0 0 cpf_msg_rcvq_pro
70 0 0 0 7264 0 0 cpf_process_tpQ
71 0 0 0 7264 0 0 CHKPT Test clien
72 0 0 0 7264 0 0 CHKPT Test clien
73 0 0 0 7264 0 0 CHKPT Test clien
74 0 0 0 7264 0 0 CHKPT Test clien
75 0 0 0 7264 0 0 CHKPT Test clien
76 0 0 0 7264 0 0 CHKPT Test clien
77 0 0 0 7264 0 0 CHKPT Test clien
78 0 0 0 7264 0 0 CHKPT Test clien
79 0 0 0 7264 0 0 CHKPT Test clien
80 0 0 0 7264 0 0 CHKPT Test clien
81 0 0 0 7264 0 0 CHKPT Test clien
82 0 0 0 13264 0 0 Crypto PKI-HA
83 0 240 240 7264 0 0 TDM Management
84 0 17908 9872 10892 0 0 RF Master Main T
85 0 1688 0 8952 0 0 RF Master Status
86 0 0 0 7264 308805 308805 Net Input
87 0 240 240 7264 0 0 Compute load avg
88 0 1045644 2093504 7264 0 0 Per-minute Jobs
89 0 1436 22800 10416 224 224 Per-Second Jobs
90 0 0 0 7264 0 0 AggMgr Process
91 0 0 0 7264 0 0 Token Daemon
92 0 0 327940 7264 0 0 Transport Port A
93 0 0 0 7264 0 0 HC Counter Timer
94 0 240 240 7264 0 0 SM Monitor
95 0 240 240 7264 0 0 Bryce I2C CMD Qu
96 0 240 240 13264 0 0 SM Installer
97 0 0 0 4264 0 0 dev_device_inser
98 0 0 0 4264 0 0 dev_device_remov
99 0 0 0 13264 0 0 sal_dpc_process
100 0 0 0 7264 0 0 ARL Table Manage
101 0 240 240 7264 0 0 ESWPPM
102 0 240 240 7264 0 0 Eswilp Storm Con
103 0 4968 240 11992 0 0 ESWILPPM
104 0 240 240 4264 0 0 Eswilp Storm Con
105 0 240 240 7264 0 0 DXMRVL
106 0 0 0 7264 0 0 esw_mrvl mat que
107 0 240 240 7264 0 0 ehwic_eswge Proc
108 0 0 0 7264 0 0 RF_INTERDEV_DELA
109 0 0 0 25264 0 0 RF_INTERDEV_SCTP
110 0 11596 5020 16840 0 0 EEM ED Identity
111 0 48888 36717140 53748 0 0 EEM ED ND
112 0 240 240 7264 0 0 ISR EVC Stats Pr
113 0 0 0 7264 0 0 VIDEO DSPRM MAIN
114 0 160460 240 167484 0 0 VNM DSPRM MAIN
115 0 7868 240 7264 2 2 FLEX DNLD MAIN
116 0 240 240 25264 0 0 UCSE Monitor
117 0 240 240 7264 0 0 Ether-Switch RBC
118 389 713045772 713031184 39928 2475 2455 Virtual Exec
119 0 0 0 7264 0 0 IGMP Snooping Pr
120 0 0 0 7264 0 0 IGMP Snooping Re
121 0 240 240 7264 0 0 Call Management
122 0 202600 316 184284 0 0 USB Startup
123 0 0 0 25264 0 0 CF_INTERDEV_SCTP
124 0 240 240 7264 0 0 BPSM stat Proces
125 0 240 0 4504 0 0 Async write proc
126 0 240 0 4504 0 0 Async write proc
127 0 240 0 4504 0 0 Async write proc
128 0 240 0 4504 0 0 Async write proc
129 0 0 0 4264 0 0 DFS flush period
130 0 240 240 7264 0 0 Serial Clk Monit
131 0 366936 212080 154328 0 0 mDNS
133 0 1992 0 9256 0 0 FHRP Main thread
134 0 1908 0 9172 0 0 VRRP Main thread
135 0 54508 416 61356 0 0 VRRS Main thread
136 0 240 240 7264 0 0 IP NAT HA BGND P
137 0 240 240 13264 0 0 Auth Manager
138 0 0 0 7264 0 0 AUTH POLICY Fram
139 0 284 284 7264 0 0 Dot1x Mgr Proces
140 0 0 0 7264 0 0 802.1x Webauth F
141 0 0 0 7264 0 0 EAP Framework
142 0 240 240 7264 0 0 CMD HANDLER
143 0 1152 240 8176 0 0 DTP Protocol
144 0 0 0 7264 0 0 SFF8472
145 0 240 240 7264 0 0 PI MATM Aging Pr
146 0 240 240 7264 0 0 EtherChnl
147 0 3244 276 10232 0 0 call_home_les_oi
148 0 240 240 13264 0 0 RG Faults Timer
149 0 240 240 13264 0 0 RG Protocol Time
150 0 240 240 13264 0 0 RG Transport Tim
151 0 0 0 7264 0 0 RG VP
152 0 240 240 7264 0 0 RG AR
153 0 0 0 7264 0 0 DHCP Snooping
154 0 240 240 10264 0 0 IP Host Track Pr
156 0 16832 240 23856 0 0 AAA Server
157 0 0 0 7264 0 0 AAA ACCT Proc
158 0 49384 0 56648 0 0 ACCT Periodic Pr
159 0 290478344 254316944 428608 259114 259114 CDP Protocol
161 0 67428 0 9032 0 0 Call Home Timer
162 0 4968 240 11992 0 0 AAA Dictionary R
163 0 240 240 13264 0 0 Ethernet LMI
164 0 240 240 10264 0 0 Ethernet OAM Pro
165 0 224 0 13488 0 0 CEF switching ba
166 0 224 0 4488 0 0 ADJ NSF process
167 0 8632 0 15896 11306 11306 TRACK Main threa
168 0 1876 140 9140 0 0 TRACK Client thr
169 0 240 240 13264 0 0 ATM OAM Input
170 0 240 240 13264 0 0 ATM OAM TIMER
171 0 240 240 7264 0 0 IPAM/ODAP Events
172 0 49384 0 62648 0 0 IPAM Manager
173 0 240 240 13264 0 0 IPAM Events
174 0 851712 445624 223048 0 0 IP ARP Adjacency
175 0 49384 0 56648 0 0 IP ARP Retry Age
176 0 3553294896 789360 23548 40762113 40762132 IP Input
177 0 0 0 7264 0 0 ICMP event handl
178 0 240 240 7264 0 0 PIM register asy
179 0 240 240 7264 0 0 NAT64 Bgnd Proce
180 0 240 240 7264 9032 9032 MOP Protocols
181 0 240 240 7264 0 0 PPP SIP
182 0 240 240 7264 0 0 PPP Bind
183 0 240 240 13264 0 0 PPP IP Route
184 0 0 0 10264 0 0 HQF TARGET DYNAM
186 0 0 0 7264 0 0 RIB LM VALIDATE
187 0 0 0 13264 0 0 SSS Manager
188 0 0 0 13264 0 0 SSS Policy Manag
189 0 0 0 7264 0 0 SSS Feature Mana
190 0 0 0 7264 0 0 SSS Feature Time
191 0 480 240 13504 102 102 Spanning Tree
192 0 240 240 13264 0 0 SSM connection m
193 0 0 0 13264 0 0 WAAS Process
194 0 0 0 7264 0 0 X.25 Encaps Mana
195 0 0 0 7264 0 0 IPv6 ping proces
196 0 11976 240 37000 0 0 Ethernet CFM
197 0 240 240 25264 0 0 Ethernet CFM PAL
198 0 240 240 25264 0 0 BD MAC Addr Agin
199 0 0 0 7264 0 0 FRR Background P
200 0 931968 56376 208452 0 0 CEF background p
201 0 224 0 13488 0 0 fib_fib_bfd_sb e
202 0 240 240 13264 0 0 NGCP SCHEDULER P
203 0 32987412 21497828 12518092 0 0 STILE PERIODIC T
204 0 240 240 13264 0 0 UV AUTO CUSTOM P
205 0 9848 524 13644 515109 515109 Flow Exporter Ti
206 0 240 240 13264 0 0 Flow Exporter Pa
207 0 224 0 10488 0 0 Tunnel FIB
208 0 0 0 7264 0 0 HQF Output Shape
209 0 0 0 7264 0 0 HQF Input Shaper
210 0 0 0 7264 0 0 IPC UDP Input
211 0 12836 3428 19264 0 0 CEF: IPv4 proces
212 0 224 0 13488 0 0 ADJ background
213 0 4044 112664 13488 0 0 Collection proce
214 0 0 0 7264 0 0 Socket Timers
215 0 0 0 7264 0 0 Critical Auth
216 0 480 240 7504 0 0 Dot1x Supplicant
217 0 480 240 7504 0 0 Dot1x Supplicant
218 0 496 240 7520 0 0 Dot1x Supplicant
219 0 972 660 8236 0 0 IGMPSN L2MCM
220 0 0 0 7264 0 0 IGMPSN MRD
221 0 0 0 7264 0 0 IGMPSN
222 0 972 660 8236 0 0 MLDSN L2MCM
223 0 0 0 7264 0 0 MRD
224 0 0 0 7264 0 0 MLD_SNOOP
225 0 240 240 4264 0 0 L2X Switching Ev
226 0 0 0 7264 0 0 MAB Framework
227 0 240 240 13264 0 0 RG Media Timer
228 0 0 0 13264 0 0 RG If-Mgr Timer
229 0 240 240 7264 0 0 IPMUXv4
230 0 240 240 7264 0 0 IPMUXv6
231 0 0 0 13264 0 0 Routing Topology
232 0 744400 658836 48028 0 0 IP RIB Update
233 0 9380 46948 12484 0 0 IP Background
234 0 178348 102656 85956 0 0 IP Connected Rou
235 0 0 0 7264 0 0 IP Traceroute
236 0 384 0 7648 0 0 Service Routing
237 0 34888 5088 37064 0 0 SR CapMan Proces
238 0 0 0 7264 0 0 SNMP Timers
239 0 85324 240 26592 0 0 SCTP Main Proces
240 0 1716 187960 13264 2064 2064 TCP Timer
241 0 18287144 3550895024 13264 0 0 TCP Protocols
242 0 944 0 26208 0 0 HTTP CORE
243 0 0 0 7264 0 0 AAA System Acct
244 0 0 0 7264 0 0 IUA Main Process
245 0 240 240 7264 0 0 RUDPV1 Main Proc
246 0 0 0 7264 0 0 bsm_timers
247 0 0 0 7264 0 0 bsm_xmt_proc
248 0 240 240 7264 0 0 PPP Compress Inp
249 0 240 240 7264 0 0 PPP Compress Res
250 0 944 0 62208 0 0 COPS
251 0 240 240 7264 0 0 Dialer Forwarder
252 0 15065064 15053020 18540 354764 354764 ADJ resolve proc
254 0 240 240 13264 0 0 Tunnel
255 0 224 0 13488 0 0 MFIB Master back
256 0 996 240 11020 0 0 MVPN Mgr Process
257 0 480 240 10504 0 0 Multicast Offloa
258 0 0 0 7264 0 0 RARP Input
259 0 240 1524 10264 0 0 static
260 0 240 240 10264 0 0 App Route Proces
261 0 0 0 10264 0 0 IPv6 RIB Cleanup
262 0 0 0 10264 0 0 IPv6 RIB Event H
263 0 0 0 10264 0 0 IP IRDP
264 0 0 0 7264 0 0 LAPB Process
265 0 0 0 7264 0 0 PAD InCall
266 0 240 240 13264 0 0 X.25 Background
267 0 38288800 38288800 10264 0 0 QoS stats proces
268 0 0 0 13264 0 0 VPDN call manage
269 0 10688 0 17816 2 2 SSH Event handle
270 0 0 0 10264 0 0 IPv6 Static Hand
271 0 240 240 7264 0 0 EFP Errd
272 0 240 240 7264 0 0 Ether EFP Proces
273 0 0 0 10264 0 0 Ethernet Datapla
274 0 0 0 10264 0 0 Ethernet PM Proc
275 0 240 240 10264 0 0 Ethernet PM Soft
276 0 0 0 13264 0 0 Ethernet PM Moni
277 0 240 240 7264 0 0 RLM groups Proce
278 0 240 240 7264 0 0 PPP NBF
279 0 1044 240 26068 0 0 Border Element p
280 0 1196 240 26220 0 0 gk process
281 0 5804 240 12828 0 0 CRM_CALL_UPDATE_
283 0 240 240 7264 0 0 AAA Cached Serve
284 0 240 240 7264 0 0 ENABLE AAA
285 0 0 0 7264 0 0 EM Background Pr
286 0 0 0 7264 0 0 IDMGR CORE
287 0 0 0 13264 0 0 Opaque Database
288 0 0 0 7264 0 0 Key chain liveke
289 0 240 240 7264 0 0 LINE AAA
290 0 48964 44508 17720 0 0 LOCAL AAA
291 0 1044 240 14068 0 0 TPLUS
292 0 4384 480 13168 0 0 EST Client
293 0 28358176 28356504 8936 3027 3027 NIST rng proc
294 0 1004 240 14028 0 0 LDAP process
295 0 51488 104 58584 0 0 MMA DB TIMER
296 0 32344 240 57368 0 0 STUN_APP
297 0 10996 0 36260 0 0 STUN_TEST
298 0 240 240 7264 0 0 VSP_MGR
299 0 240 240 4264 0 0 RSCMSM VOLUME MO
300 0 240 240 7264 0 0 CSDB Timer proce
301 0 0 0 7264 0 0 crypto engine pr
302 0 0 0 13264 0 0 RSA background p
303 0 361220 298216 76908 1 1 Crypto CA
304 0 240 240 13264 0 0 Crypto PKI-CRL
305 0 0 0 13264 0 0 Crypto PKI-Rev-P
306 0 944 0 14208 0 0 PKI OCSP
307 0 0 0 13264 0 0 PKI Revocation
308 0 0 0 13264 0 0 encrypt proc
309 0 5564 104 12828 0 0 MMA DP TIMER
310 0 6110820 2384 5522676 11 11 FLEX DSPRM MAIN
311 0 0 0 7264 0 0 FLEX DSP KEEPALI
312 0 35816 0 49080 877 877 CCVPM_HTSP
313 0 240 240 7264 0 0 VPM_MWI_BACKGROU
314 0 564 240 7588 0 0 VPM_CABLE_STAT_P
315 0 932 0 8196 0 0 VPM_CONN_CHK_BAC
316 0 436 0 7700 0 0 CCVPM_R2
317 0 18792 0 26056 0 0 IP TRUST Registe
318 0 0 0 7264 0 0 EPHONE MWI Refre
319 0 0 0 7264 0 0 FB/KS Log HouseK
320 0 240 240 7264 0 0 EPHONE MWI BG Pr
321 0 8244 0 15508 0 0 Skinny HW confer
322 0 0 0 13264 0 0 CCSIP_EVENT_TRAC
323 0 860 240 25884 0 0 CTI Front End Pr
324 0 240 240 10264 0 0 CTI Call Control
325 0 240 240 7264 0 0 CTI Line Monitor
326 0 0 0 7264 0 0 CME CTI Device M
327 0 516 516 13264 0 0 VOICE REG BG Pro
328 0 240 240 13264 0 0 CME Extension Mo
329 0 0 0 7264 0 0 Presence Process
330 0 0 0 7264 0 0 DS0 PCM Capture
331 0 7608 240 20632 0 0 Sip MPA
333 0 944 0 62208 0 0 http client proc
335 0 11980012 11689424 300852 1 0 QOS_MODULE_MAIN
336 0 284 0 25548 0 0 RPMS_PROC_MAIN
337 0 0 0 25264 0 0 VoIP AAA
338 0 25684 240 32708 0 0 Dialog Manager
339 0 230384 0 243648 0 0 VOIP_FMD_MAIN
340 0 0 0 10264 0 0 Licensing MIB pr
341 0 240 240 7264 0 0 Control-plane ho
342 0 0 0 7264 0 0 PM Callback
343 0 240 240 7264 0 0 dhcp snooping sw
345 0 141112 712992 7264 0 0 AAA SEND STOP EV
346 0 0 0 13264 0 0 Test AAA Client
347 0 2532 0 9796 0 0 dcm_cli_engine
348 0 5592 292 12668 0 0 dcm_cli_provider
349 0 20444 5808 22100 0 0 DCM Core Thread
350 0 11624 4988 16900 0 0 EEM ED Routing
351 0 290260 4988 295536 6467 6435 EEM ED Syslog
352 0 214428 4988 219704 0 0 EEM ED Generic
353 0 11740 5040 16964 0 0 EEM ED NHRP
354 0 16360 4988 21636 0 0 EEM ED Track
355 0 13412 4988 18688 0 0 EEM ED Resource
356 0 240 240 7264 0 0 RMON Recycle Pro
357 0 240 240 7264 0 0 RMON Deferred Se
358 0 0 0 7264 0 0 Syslog Traps
359 0 0 0 7264 0 0 WAN Optimization
361 0 10512 1552 14904 2 2 VLAN Manager
362 0 36776 0 43364 4 4 MLD
363 0 2492 480 15276 0 0 RBM CORE
364 0 3316 480 10100 0 0 CTS credentials
365 0 1385140 20728 1374556 0 0 EEM Server
366 0 130828 113988 118808 0 0 Call Home proces
367 0 10920 756 9500 0 0 Call Home DS
368 0 1976 168 8952 0 0 Call Home DSfile
369 0 9852 1816 15028 0 0 DCM snmp dp Thre
370 0 3536 264 10456 0 0 snmp dcm ma shim
371 0 10176 14792 14120 0 0 Bulkstat-Client
372 0 3848 264 10728 0 0 dcm_expression_p
373 0 13052 1208 22108 0 0 EEM Policy Direc
374 0 338305400 338285924 14316 2491716 2491716 IP SNMP
375 0 11516 4988 16792 0 0 EEM ED CLI
376 0 11572 4988 16848 0 0 EEM ED Counter
377 0 12268 4988 17544 0 0 EEM ED Interface
378 0 11516 4988 16792 0 0 EEM ED IOSWD
379 0 11516 4988 16792 0 0 EEM ED None
380 0 11516 4988 16792 0 0 EEM ED OIR
381 0 12332 5024 17116 0 0 EEM ED RF
382 0 11516 4988 16792 0 0 EEM ED SNMP
383 0 11516 4988 16792 0 0 EEM ED SNMP Obje
384 0 11620 4988 16896 0 0 EEM ED SNMP Noti
385 0 11684 4988 16960 0 0 EEM ED Timer
386 0 16244 4988 21520 0 0 EEM ED Test
387 0 11516 4988 16792 0 0 EEM ED Config
388 0 11516 4988 16792 0 0 EEM ED Env
389 0 17296 5276 22572 0 0 EEM ED DS
390 0 16816 4988 22092 0 0 EEM ED CRASH
391 0 125047360 0 16108 0 0 PDU DISPATCHER
392 0 16672 4988 21948 0 0 EEM ED Nf
393 0 1787508 1787508 13264 6475 6475 Syslog
395 0 1656 0 8920 0 0 qos_mon_periodic
396 0 11516 4988 16792 0 0 EEM ED RPC
397 0 0 0 7264 0 0 IP SLAs ICMP Jit
398 0 0 0 7264 0 0 IP SLAs Jitter E
399 0 11516 4988 16792 0 0 EEM ED Ipsla
400 0 0 0 7264 0 0 IP SLAs Ethernet
401 0 0 0 7264 0 0 trunk conditioni
402 0 4660 0 11924 0 0 trunk conditioni
403 0 0 0 7264 0 0 VDC process
404 0 240 0 25504 0 0 tHUB
405 0 1981683332 1981683256 13340 0 0 mdns Timer Proce
406 0 1728 240 14752 0 0 MRIB Process
407 0 240 240 7264 0 0 TRP_PSEUDOTIMER
408 0 7324 240 14348 0 0 Resource Monitor
409 0 240 240 7264 0 0 Resource Availab
410 0 3644 240 16668 0 0 TRPAPP
411 0 4452192 9628 208072 0 0 CC-API_VCM
412 0 209336 607332 184716 1502 1502 VOIP_RTCP
413 0 240 240 13264 0 0 confmsp
414 0 237772 532 43656 0 0 Session Applicat
415 0 2617528 1097560 185316 2225 2225 DSMP
416 0 2261872 1528392 250408 218 218 VTSP
417 0 41192 0 66456 0 0 TSP
418 0 412644 240 437668 0 0 swmtp_msp
419 0 2600 240 15624 0 0 RECMSPAPP
420 0 828 0 14092 0 0 lib_off_app
421 0 0 0 7264 0 0 Media Record
422 0 240 240 7264 0 0 Voice Player
423 0 0 0 7264 0 0 Resource Measure
424 0 240 240 13264 0 0 vxcmsp
425 0 240 240 7264 0 0 Synthetic Video
426 0 246156 240 259180 0 0 VOICE_HA_ACTIVE
427 0 240 240 13264 0 0 VOICE_HA_STANDBY
428 0 39320 240 100344 0 0 Voip HA Session
429 0 7552 772 14332 0 0 EEM Helper Threa
430 0 396913640 521958188 13296 0 0 SNMP ENGINE
431 0 7741252 6501744 1568092 657 657 CCH323_CT
432 0 0 0 7264 0 0 CCH323_DNS
433 0 2682448 240 2743472 0 0 CCSIP_SPI_CONTRO
434 0 0 0 13264 0 0 CCSIP_DNS
435 0 167608 240 192632 0 0 CCSIP_UDP_SOCKET
436 0 312432 240 337456 0 0 CCSIP_TCP_SOCKET
437 0 509228 0 534492 0 0 RTPSPI
438 0 1260 240 14316 0 0 IP SNMPV6
439 0 0 0 13296 0 0 SNMP ConfCopyPro
440 0 240 240 13296 0 0 SNMP Traps
441 0 357392 296012 60092 32033 32033 DHCPD Receive
442 0 0 0 13264 4888395 4888394 FNF Cache Ager P
443 0 0 0 13300 0 0 NBAR timer tick
444 0 0 0 13264 0 0 CFT Timer Proces
445 0 240 240 13264 0 0 PPP manager
446 0 240 240 13264 0 0 PPP Events
447 0 240 240 7264 0 0 Multilink PPP
448 0 240 240 7264 0 0 Multilink event
449 0 109448 55828 64280 726014 726014 IP SLAs XOS Even
450 0 1787240 1775500 17316 44260 44260 NTP
451 0 0 328 7128 1 1 DHCPD Timer
452 0 224 0 7352 0 0 DHCPD Database
113344884 Total
20 Replies 20
Again, if physical port goes down, because of ISP issue, normal static routing should fail over.
Only when port stays up but you no longer have an end-to-end connection do you need something dynamic, like SLA or a dynamic routing protocol.
Unfortunately, all the networks I've supported generally used a dynamic routing protocol to support fail over situations, so I'm not up on setting up SLA tracking, but they likely should be able to provide what you need.
HI,
One side Dynamic protocol and remote side router is static routing , in the scenario whether working fine? Could you share the any one of dynamic routing protocol SLA tracking commands asap.
Could you share the causes for the CPU utilization on the router asap?
Muthukumar
Hello Muthukumar,
I try to ask you again in order to troubleshoot High cpu usage
can you post the output of the following command:
show proc cpu sorted 1min | exclude 0.00
to see the TOP CPU users among the processes once you provide that information it is possible to go on with analysis.
About use of both MPLS links I recommend to use a dynamic routing protoco on both routers both sidesl to achieve fault tolerance and load balancing.
There are  a lot of dial-peers configured your issues with C2901 may arise from this area when compared with C2911 rather then from few errors on data interfaces.
Hope to help
Giuseppe
HI team,
                Pl. find the output and it seems cpu utilization is high whenever check last 60 minutes. Please suggest
CNNW0000001>en
Password:
CNNW0000001#
CNNW0000001#
CNNW0000001#sh int g0/3/0
reliability 255/255, txload 67/255, rxload 239/255
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 171
5 minute input rate 3850000 bits/sec, 916 packets/sec
5 minute output rate 1091000 bits/sec, 780 packets/sec
68565897 packets input, 1407747912 bytes, 0 no buffer
Received 301039 broadcasts (0 IP multicasts)
46373400 packets output, 3225256291 bytes, 0 underruns
15469 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
CNNW0000001#
CNNW0000001#
CNNW0000001#
CNNW0000001#
CNNW0000001#
CNNW0000001#show proc cpu sorted 1min | exclude 0.00
CPU utilization for five seconds: 18%/14%; one minute: 14%; five minutes: 17%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
208 42748 115555245 0 0.47% 0.44% 0.42% 0 HQF Output Shape
442 228020 467660 487 0.31% 0.29% 0.31% 0 FNF Cache Ager P
443 29688 57940289 0 0.23% 0.23% 0.23% 0 NBAR timer tick
13 717332 7774 92273 1.67% 0.20% 0.13% 0 Licensing Auto U
16 420108 466326 900 0.47% 0.09% 0.06% 0 Environmental mo
445 17264 14574834 1 0.07% 0.08% 0.07% 0 PPP manager
89 34940 467190 74 0.07% 0.07% 0.07% 0 Per-Second Jobs
172 11332 14540520 0 0.07% 0.07% 0.07% 0 IPAM Manager
135 13488 7288774 1 0.07% 0.06% 0.07% 0 VRRS Main thread
309 13456 7288787 1 0.07% 0.05% 0.06% 0 MMA DP TIMER
62 52 183 284 0.15% 0.05% 0.01% 388 Virtual Exec
CNNW0000001#sh processes cpu history
CNNW0000001 09:52:23 AM Thursday May 6 2021 IST
111111111111111111111111111111111111111111111111111111111111
333555555555544444999996666677777666664444455555444448888833
100
90
80
70
60
50
40
30
20 ********** ******************** ***** *****
128112828217882791211262112292258211222862199217217771928129
861665498070770198254181894662192088651508955290070446321498
100 * * ** *
90 * ** * * * ** * *
80 * * * ** * * * * ** * * *
70 * * * *** ** * * * * ** * *** * * *
60 * * * *** ** * * ** ** ** * *** * * *
50 * * * *** ** * * ** ** ** * *** * * *
40 * * * *** ** * * ** #* ** * *** * * *
30 *# *#*# *#* *# * *# ## ** ##* #* * *** * * **
20 ###**#####*###*##*** *#**#######################**##**#*# *#
91111111111199999999999991 568999999999991 188999999999
970200220101577777882677967665588965867787777488597555666788144777788899
100 * ******** **** ******* *** *********
90 * ************* ************ *********
80 * ************* ************ ***********
70 * ************* ************* ***********
60 * ************* ************** ***********
50 * ************* ************** ***********
40 * ************* ************** ***********
30 * ************* ************** ***********
20 #* ****#########* *****###*####** ***########
10 #************############************############*************##########
CNNW0000001#
CNNW0000001#
CNNW0000001#
CNNW0000001#sh memory statistics history
------------------ History of Processor Mempool ------------------
CNNW0000001 09:52:35 AM Thursday May 6 2021 IST
666666666666666666666666666666666666666666666666666666666666
555555555555555555555555555555555555555555555555555555555555
100
90
80
70 ************************************************************
60 ************************************************************
50 ************************************************************
40 ************************************************************
30 ************************************************************
20 ************************************************************
Free memory per second (last 60 seconds)
100
90
80
70 ############################################################
60 ############################################################
50 ############################################################
40 ############################################################
30 ############################################################
20 ############################################################
Free memory per minute (last 60 minutes)
* = maximum # = average
666666666666666666666666666666666666666666666666666666666666666666666666
555555555555555555555555555555555555555555555555555555555555555555555555
100
90
80
70 ########################################################################
60 ########################################################################
50 ########################################################################
40 ########################################################################
30 ########################################################################
20 ########################################################################
10 ########################################################################
Free memory per hour (last 72 hours)
------------------ History of I/O Mempool ------------------
100
90
80
70
100
90
80
70
111111111111111111111111111111111111111111111111111111111111111111111111
100
90
80
70
CNNW0000001#
@MuthukumarParamasivan43009 wrote:
rxload 239/255
Found it!
Hi team,
              Any suggestion to reduce the rx load or have to increase mpls link bandwidth.
