CRC errors
Just Kennie
GigabitEthernet0/1 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 0021.a09c.72c1 (bia 0021.a09c.72c1)
Description: (10/full)
Internet address is XX.XX.XX.XX/30
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 238/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 10Mb/s, media type is T
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:18:07
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 69000 bits/sec, 28 packets/sec
5 minute output rate 37000 bits/sec, 23 packets/sec
37670 packets input, 13786943 bytes, 0 no buffer
Received 1076 broadcasts, 660 runts, 0 giants, 0 throttles
4531 input errors, 3871 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
28496 packets output, 8953134 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
FROM MY OUTPUT ABOVE, I AM HAVING SO MANY PACKECTS IN.....
PLEASE WHATS THE CAUSE, WHAT CAN I DO
mvsheik123
Level 7
Level 7
Try to hard code the switch port and the server/PC connected to the switch port to 1000/Full). If that does not resolve, try changing the cable.
hth
MS
**Rate helpful posts**
