CRC troubleshooting - Cisco Catalyst
mcow
Are there any troubleshooting commands that can be performed to rule out a transceiver issue? In the past I typically start at one end of the link and start replacing sfp's and fiber optic patch cords until the CRC errors stop incrementing.
5 Replies 5
pman
CRC Indicates that the cyclic redundancy checksum generated by the originating LAN station or far-end device does not match the checksum calculated from the data received. On a LAN, this usually indicates noise or transmission problems on the LAN interface or the LAN bus itself. A high number of CRCs is usually the result of collisions or a station transmitting bad data.
show interface <type> <num>
show interface <type> <num> controller
try this one:
https://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1904.html
Also, one more thing to note.  This interfaces is a point to point link between two Cat 9000's and I cleared the counters on the interface the other day when I first noticed this.  Please see attachment.
what is type of SW you use
Cut-through
or
storage ?
Hello
sh interface capabilities
sh interface transceiver detail
sh interface  xxxx transceiver detail
Kind Regards
Paul
As mentioned above, this interfaces is a point to point link between two Cat 9000's and I cleared the counters on the interface the other day when I first noticed this.  Please see attachment.
Interface
Twe2/0/21
