CRCs incrementing
fadyawad1
Dear All,
Just a quick one, i've 380 CRC errors incremented on the interface between me and the ISP (in a period of 3hours)
Last clearing of "show interface" counters 03:18:41
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 527000 bits/sec, 201 packets/sec
  5 minute output rate 445000 bits/sec, 199 packets/sec
     1622419 packets input, 533479907 bytes
     Received 276 broadcasts, 84 runts, 0 giants, 0 throttles
     384 input errors, 384 CRC, 0 frame, 0 overrun, 0 ignored
Is that normal or should be checked.
Fady
6 Replies 6
John Blakley
It needs to be checked. You can try replacing the cable first to see if it helps. What type of connection is this? Serial? Ethernet?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
thanks John, this is an Ethernet connection.
Will try to change the cable and see.
Thanks again.
Can you post your "show int "? I'm looking for something specific....
HTH,
John
FastEthernet0/0 is up, line protocol is up
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 03:33:37
  5 minute input rate 517000 bits/sec, 201 packets/sec
  5 minute output rate 457000 bits/sec, 199 packets/sec
     1804975 packets input, 591659825 bytes
     Received 292 broadcasts, 90 runts, 0 giants, 0 throttles
     424 input errors, 424 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     1802931 packets output, 517603366 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
Thanks for posting this. Speed/duplex is correct. Usually, CRC errors are from mismatched duplex settings. How do you have your interface configured? Auto or hardcoded? If it's auto, you may try to change it to 100/full hardcoded. If it's hardcoded, you may try to change it to auto for speed/duplex. The provider could have their side at auto and you have yours hard coded. If that's the case, the other end could see half duplex and it could cause your crc errors.
HTH,
John
Hi John,
thanks for the useful info, honestly i don't know how it is configured as it was implemented back in the days before me.
Will try to check this and as well reach out to the provider and see what's on their side.
Fady
