Cisco 1801 cannot set tx-ring-limit on fastethernet0
bwilks
Hi, I am trying to set the tx-ring-limit on fastethernet0 interface to 2 but it defaults to 16.
I am configuring QOS for voice, I done tx-ring-limit tuning before on atm interfaces without any problems usually set to to 2 or 3.
Cisco reference
https://supportforums.cisco.com/docs/DOC-1509
ios
c180x-advipservicesk9-mz.151-4.M5.bin
router
Cisco 1801
console output
gw02(config-if)#tx-ring-limit ?
  <1-32767>  Number (ring limit)
sh ru
interface FastEthernet0
bandwidth 8000
ip address xxx.xxx.xxx.xxx 255.255.255.240
ip access-group 104 in
ip nat outside
ip inspect CCP_LOW out
ip virtual-reassembly in
tx-ring-limit 16
tx-queue-limit 16
duplex auto
speed auto
crypto map IPSECVPN
service-policy output XXXVPN
Any help would be appreciated thanks
bwilks
Update, also tried a few other setting to see if it would make any difference but it did not.
speed 10
full-duplex
ip mtu 720
Does anyone have any thoughts on the matter?
