Create New User For SSH
kemarnorton
Hi Team,
Seeking some help. Cut long story short the person they had that was doing the networking leave the company and change most of the username password for the equipment.
I was able to console in some of the equipment and I tired to create a new user with the command below but when I tried to SSH in I keep getting denied. Note the switch is fully configured for SSH and more all I want to do is to add a next user for SSH and then remove the old user.
username cisco privilege 15 secret password
4 Accepted Solutions
You can see it with show run | section vty
Regards, LG
*** Please Rate All Helpful Responses ***
You must have login local configured on line vty 0 4 in order to use the local users.
Regards, LG
Hello @kemarnorton ,
as explained by @liviu.gheorghe  you need login local under all the line vty .
With login command authentication is based only on a password and it asks only for the configured password.
so
conf t
line vty 0 4
no login
login local
line vty 5 15
no login
login local
do this from console
Hope to help
Giuseppe
>> I also see this enable secret 5 $1$oWS/$gM30R.Jl.srXeqTr7OYRt. what does the 5 represent I don't remember learning this in my CCNA course.
the 5 is just a number that says with what encrpytion method  the secret has been encrpyted.
Hope to help
Giuseppe
15 Replies 15
in addition to the user creation on the network equipment, you also have to configure the vty lines:
line vty 0 4
login local
transport input ssh
Regards, LG
Those commands was already configured when the first user was created. Do I have to reconfigure those commands with the new user I am creating had well?
check if the command has been accepted and implemented using:
show run | inc username
check if aaa is configured using
show run | inc aaa
if the only line you see is:
no aaa new-model
your device is not using AAA
alternatively try to use a command without priv 15 keyword  in the username definition
And configure enable secret on the device
Hope to help
Giuseppe
Yes this no aaa new-mode command is configured on the switch
balaji.bandi
what model of the switch ? and IOS Code running on it ?
As you mentioned before it was working with old users and only new user not working, what logs you see on the switch (other than on client denied ?)
we need to know do you have any AAA model enabled ?
You may try - username cisco privilege 15 secret 5 xxxxxxxxxxxxxxx
Also check on VTY lines you have any
line vty 0 4
privilege level 15
can you post
show run | in aaa
show run | in username (remove password)
show run | begin vty
BB
All the line commands was already configured when the first user was created do I need to reconfigure then with the new user I am adding?
Is there a command access-class <...> in on the line vty ?
Regards, LG
No that I remember. Apart from the show command is there a specific command I can run to see this?
Regards, LG
this is what I am seeing for vty lines
line vty 0 4
password 7 12355530420548341D0F
login
transport input telnet
line vty 5 15
password 7 0723716B1E075D352036
login
transport input ssh
Regards, LG
Thanks, this works I am now able to login
so
conf t
line vty 0 4
no login
login local
line vty 5 15
no login
login local
Hope to help
Giuseppe
I work thanks all.
