Create Stub Router
saifulsayuti96
hi how do you create stub router using packet tracer version 8.2.1
I have tried this command but did not work
R2(config-router)#eigrp stub
% Invalid input detected at '^' marker.
Packet tracer is Limited
Some command not accept.
Ditto to what @MHM Cisco World wrote.
Packet Tracer is a simulator, not an emulator.  It often only provides a subnet of the features available on the device it is simulating.
Best you might do with PT, is try using the very latest version, but that's not a guarantee Cisco has added support for some feature.
Your alternatives are, obtain real hardware you can lab with, or obtain an emulator, like GNS3 or CML.  (I mention those two because I believe @MHM Cisco World often labs issues with GNS3, and I use CML when I'm trying to lab something not supported with PT.)
