crypto isakmp policy got rejected in a ISR C1111-4P license problem?
chris4real
I'm trying to configure IPSEC on a new ISR C1111-4P but showing an error when I try to execute the command.
so either the syntax has changed with the new XE IOS or is a license problem? how I can tell?
Here is the version output and the license output.
Router#show license all
Smart Licensing Status
Smart Licensing is ENABLED
License Conversion:
Automatic Conversion Enabled: False
Status: Not started
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: cslu
Cslu address: <empty>
Proxy:
Not Configured
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Jun 14 16:01:27 2024 UTC
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Jun 15 16:03:27 2023 UTC
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
License Usage
securityk9_npe (ISR_1100_4P_Security_NPE):
Description: securityk9_npe
Count: 1
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: securityk9_npe
Feature Description: securityk9_npe
Enforcement type: NOT ENFORCED
License type: Perpetual
Product Information
UDI: PID:C1111-4PLTEEA,SN:FGL2607L4AE
Agent Version
Smart Agent for Licensing: 5.0.6_rel/47
License Authorizations
Overall status:
Active: PID:C1111-4PLTEEA,SN:FGL2607L4AE
Status: NOT INSTALLED
Purchased Licenses:
No Purchase Information Available
Router#show ver
Cisco IOS XE Software, Version 17.04.01a
Cisco IOS Software [Bengaluru], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 17.4.1a, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 17-Dec-20 22:38 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: (c)
Router uptime is 10 minutes
Uptime for this control processor is 11 minutes
System returned to ROM by PowerOn
System image file is "bootflash:c1100-universalk9_npe.17.04.01a.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9_npe None Smart License None
securityk9_npe
appxk9
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None Smart License None
securityk9 securityk9_npe Smart License securityk9_npe
ipbase ipbasek9 Smart License ipbasek9
The current throughput level is unthrottled
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco C1111-4PLTEEA (1RU) processor with 1383112K/6147K bytes of memory.
Processor board ID FGL2607L4AE
Router operating mode: Autonomous
1 Virtual Ethernet interface
6 Gigabit Ethernet interfaces
2 Cellular interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
2945023K bytes of flash memory at bootflash:.
11 Replies 11
Show license status
Please share this
here is the output:
Router#show license status
Utility:
Status: DISABLED
Status: ENABLED
Data Privacy:
Transport:
Type: cslu
Proxy:
Not Configured
Policy:
Miscellaneous:
Custom Id: <empty>
Usage Reporting:
Next ACK deadline: Jun 15 14:12:23 2024 UTC
Next report push: Jun 16 14:14:23 2023 UTC
License Usage
Count: 1
Version: 1.0
Status: IN USE
NPE is non-payload encryption, so use image without NPE (just universal one). Download image and upgrade the router.
NPE image does not support IPSec.
https://community.cisco.com/t5/other-network-architecture-subjects/image-with-without-payload-encryption/td-p/1766672
HTH,
NPE is support IPSec but not strong encryption
what I think is you need to activate the license only
Actually, @MHM Cisco World  is right. In reliability, NPE is "no strong encryption". It was my bad that I explained it as no IPSec.
But upgrade to non-NPE image will help in any case. To understand issue in npe case, share show license related different outputs (whatever supported from show license suite / show license / show license feature / show license detail etc.)
HTH,
Here are all the different outputs:
Router#show license summary
License Usage:
License Entitlement Tag Count Status
securityk9_npe (ISR_1100_4P_Security_NPE) 1 IN USE
Router#show license authorization
Overall status:
Active: PID:C1111-4PLTEEA,SN:FGL2607L4AQ
Purchased Licenses:
Router#show license usage
License Authorization:
Status: Not Applicable
Count: 1
Version: 1.0
Status: IN USE
Utility:
Status: DISABLED
Status: ENABLED
Data Privacy:
Transport:
Type: cslu
Proxy:
Not Configured
Policy:
Miscellaneous:
Custom Id: <empty>
Usage Reporting:
Router#show license tech support
Smart Licensing Tech Support info
License Conversion:
Status: Not started
<none>
Utility:
Status: DISABLED
Status: ENABLED
Data Privacy:
Transport:
Type: cslu
Proxy:
Address: <empty>
Port: <empty>
Username: <empty>
Password: <empty>
Server Identity Check: False
Miscellaneous:
Custom Id: <empty>
Policy:
Usage Reporting:
Reporting push interval: 30 days State(2) InPolicy(365)
License Usage
Handle: 1
License: securityk9_npe
Entitlement Tag: regid.2017-04.com.cisco.ISR_1100_4P_Security_NPE,1.0_c017fc1b-2fb0-4ea1-a8b4-88aeca4aa084
Count: 1
Version: 1.0
Status: IN USE(15)
Status time: Jun 16 14:04:20 2023 UTC
Request Time: Jun 16 14:04:20 2023 UTC
Measurements:
ENTITLEMENT:
Interval: 00:15:00
Current Value: 1
Soft Enforced: True
Product Information
UDI: PID:C1111-4PLTEEA,SN:FGL2607L4AQ
Agent Version
Upcoming Scheduled Jobs
Current time: Jun 16 14:36:07 2023 UTC
Daily: Jun 17 14:04:04 2023 UTC (23 hours, 27 minutes, 57 seconds remaining)
Authorization Renewal: Expired Not Rescheduled
Init Flag Check: Expired Not Rescheduled
Reservation configuration mismatch between nodes in HA mode: Expired Not Rescheduled
Start Utility Measurements: Jun 16 14:42:23 2023 UTC (6 minutes, 16 seconds remaining)
Send Utility RUM reports: Jun 17 14:15:20 2023 UTC (23 hours, 39 minutes, 13 seconds remaining)
Save unreported RUM Reports: Jun 16 15:27:33 2023 UTC (51 minutes, 26 seconds remaining)
Process Utility RUM reports: Jun 17 14:12:22 2023 UTC (23 hours, 36 minutes, 15 seconds remaining)
External Event: Jun 16 15:12:21 2023 UTC (36 minutes, 14 seconds remaining)
Operational Model: Expired Not Rescheduled
Hello Message: Expired Not Rescheduled
Communication Statistics:
Communication Level Allowed: INDIRECT
Overall State: <empty>
Trust Establishment:
Attempts: Total=0, Success=0, Fail=0 Ongoing Failure: Overall=0 Communication=0
Last Response: <none>
Failure Reason: <none>
Last Success Time: <none>
Last Failure Time: <none>
Trust Acknowledgement:
Usage Reporting:
Result Polling:
Authorization Request:
Authorization Confirmation:
Authorization Return:
Trust Sync:
Hello Message:
Attempts: Total=2, Success=0, Fail=2 Ongoing Failure: Overall=2 Communication=2
Last Response: NO REPLY on Jun 16 14:15:21 2023 UTC
Last Failure Time: Jun 16 14:15:21 2023 UTC
License Certificates
Production Cert: True
Not registered. No certificates installed
HA Info
RP Role: Active
Chassis Role: Active
Behavior Role: Active
RMF: True
CF: True
CF State: Stateless
Message Flow Allowed: True
Reservation Info
License reservation: DISABLED
Overall status:
Reservation status: NOT INSTALLED
Request code: <none>
Last return code: <none>
Last Confirmation code: <none>
Reservation authorization code: <none>
Specified license reservations:
Purchased Licenses:
Other Info
Software ID: regid.2017-04.com.cisco.ISR_1100_4P,1.0_00a7981b-7a6d-421d-a5ae-794963d4e1c7
Agent State: authorized
TS enable: True
Transport: cslu
Locale: en_US.UTF-8
Debug flags: 0x7
Privacy Send Hostname: True
Privacy Send IP: True
Build type:: Production
sizeof(char) : 1
sizeof(int) : 4
sizeof(long) : 4
sizeof(char *): 8
sizeof(time_t): 4
sizeof(size_t): 8
Endian: Big
Write Erase Occurred: False
XOS version: 0.12.0.0
Config Persist Received: True
Message Version: 1.3
connect_info.name: <empty>
connect_info.version: <empty>
connect_info.additional: <empty>
connect_info.prod: False
connect_info.capabilities: <empty>
agent.capabilities: UTILITY, DLC, AppHA, MULTITIER, EXPORT_2, OK_TRY_AGAIN, POLICY_USAGE
Check Point Interface: True
Config Management Interface: False
License Map Interface: True
HA Interface: True
Trusted Store Interface: True
Platform Data Interface: True
Crypto Version 2 Interface: False
SAPluginMgmtInterfaceMutex: True
SAPluginMgmtIPDomainName: True
SmartAgentClientWaitForServer: 2000
SmartAgentCmReTrySend: True
SmartAgentClientIsUnified: True
SmartAgentCmClient: True
SmartAgentClientName: UnifiedClient
builtInEncryption: True
enableOnInit: True
routingReadyByEvent: True
systemInitByEvent: True
SmartTransportServerIdCheck: True
SmartTransportProxySupport: True
SmartAgentMaxRumMemory: 50
SmartAgentConcurrentThreadMax: 10
SmartAgentPolicyControllerModel: False
SmartAgentPolicyModel: True
SmartAgentFederalLicense: True
SmartAgentMultiTenant: False
attr365DayEvalSyslog: True
checkPointWriteOnly: False
SmartAgentDelayCertValidation: False
enableByDefault: False
conversionAutomatic: False
conversionAllowed: True
storageEncryptDisable: False
storageLoadUnencryptedDisable: False
TSPluginDisable: False
bypassUDICheck: False
loggingAddTStamp: False
loggingAddTid: True
HighAvailabilityOverrideEvent: UnknownPlatformEvent
platformIndependentOverrideEvent: UnknownPlatformEvent
platformOverrideEvent: UnknownPlatformEvent
WaitForHaRole: False
standbyIsHot: False
chkPtType: 2
delayCommInit: False
roleByEvent: True
maxTraceLength: 150
traceAlwaysOn: True
debugFlags: 0
Event log max size: 5120 KB
Event log current size: 8 KB
Local Device: No Trust Data
Overall Trust: No ID
Platform Provided Mapping Table
C1111-4PLTEEA: Total licenses found: 15759
Enforced Licenses:
P:C1111-4PLTEEA,S:FGL2607L4AQ:
No PD enforced licenses
I'm seeing that the license says "not enforced" could be this the issue? and if does how can I enforced.
chris4real
I loaded a non NPE image to the router, but didnt enable the ipsec feature.
Router uptime is 2 minutes
Uptime for this control processor is 4 minutes
System returned to ROM by Reload Command
System image file is "flash:c1100-universalk9.17.08.01a.SPA.bin"
export@cisco.com.
FoundationSuiteK9 None Smart License None
securityk9
appxk9
uck9 None Smart License None
securityk9 None Smart License None
Smart Licensing Status: Smart Licensing Using Policy
cisco C1111-4PLTEEA (1RU) processor with 1355460K/6147K bytes of memory.
Processor board ID FGL2607L4AQ
2 Virtual Ethernet interfaces
Seems like the K9 license got disable with this image.
Account Information:
Smart Account: <none>
Virtual Account: <none>
License Usage:
No licenses in use
License Conversion:
Automatic Conversion Enabled: True
Status: Not started
<none>
Utility:
Status: DISABLED
Status: ENABLED
Data Privacy:
Transport:
Type: cslu
Proxy:
Not Configured
VRF:
Not Configured
Miscellaneous:
Custom Id: <empty>
Policy:
Usage Reporting:
Next report push: Jun 16 15:44:47 2023 UTC
License Usage
No licenses in use
Product Information
Agent Version
Smart Agent for Licensing: 5.4.15_rel/58
Overall status:
Purchased Licenses:
Usage Report Summary:
Total: 2, Purged: 0
Total Acknowledged Received: 0, Waiting for Ack: 0
Available to Report: 2 Collecting Data: 0
Or
ip crypto isakmp policy
Whcih command is not accept?
for crypto shows this options:
Router(config)#crypto ?
RSA-key-pair RSA key pair
key Long term key operations
pki Public Key components
provisioning Secure Device Provisioning
wui Crypto HTTP configuration interfaces
IP crypto is no available.
Router(config)#ip crypto
% Invalid input detected at '^' marker.
check the license is enable or not via show license feature
Actually the show license feature is not available, it marks a error.
router2054#show license feature
router2054#show license ?
all Show license all information
authorization Show license status information
data show license data conversion information
eventlog Show license eventlog information
history show license history information
reservation Show license reservation information
status Show license status information
suites Show license suite information
summary Show license summary
tech show license tech support information
udi Show license udi information
usage Show license usage information
