Creating L2TP tunnel
GRIMESI
Is there a way to create an l2tp tunnel between two routers, without using encryption or vpn? I just need to extend a layer 2 network for multicast traffic. thanks.
shivlu jain
Level 5
Level 5
Grimes
You can do this with the help of PSEUDOWIRE and XCONNECT
Router# pseudowire-class abc
Router(config-pw)# encapsulation l2tpv3
Router(config-pw)# ip local interface loopback 0
int fa0/0.10
encapsulation dot1q 10
Router(config-if)# xconnect peer-router-id vc-id encapsulation l2tpv3 pseudowire-class abc
regards
shivlu
shivlu jain
Level 5
Level 5
Grimes
int fa0/0.10
regards
shivlu
