creating local user in Router/Switch
raju
I'm trying to create local users in my Switch /Routers with different privileges. My requirement is when the user telnets to Switch /Router , he should get a screen with username rather than using login command from unprivileged mode . Now to to login , I telnet to Router and from there(unprivileged mode) I use login command to put the user name and then password.
Raju
JonathanUK
Level 3
Level 3
Hi Raju
Please see the link below it has all the info and config examples you require
http://www.cisco.com/en/US/products/sw/iosswrel/ps1818/products_configuration_example09186a0080204528.shtml
Jonathan
