Creative solution to limit Min/Max IP MTU
fsebera
Level 4
Level 4
Hey guys,
This is probably a strange one-off request but thought I would try anyway.  We have a situation where our service provider consistently and continuously drops certain size IPSec packets.  Long story short, contracts have been signed and accepted by all parties and no one is budging or fixing the issue and thus the link is useless. I'm an engineer and cannot fix stupid. However, as an engineer, I'm thinking perhaps there may be a way to circumvent this issue.
Cisco ASR1002-X router IOS-XE 15.x
Looking for a solution to change certain size IPSec packets to a different size and thus avoid the hole.
Example:
Packets in the range of 64 - 852 pass and are routed to remote sites
Packets in the range of 853 - 872 fail and are dropped by the service provider
Packets in the range of 873 - 1500 pass and are routed to remote sites
Thank you
Frank
ngkin2010
Level 7
Level 7
Your service provider is very 'interesting', which is totally unacceptable. If i were you, I would keep escalate the issue...
Btw, with this interesting scenario, all you want to do is to increase the packet size for packets (that in the certain size).
To do this, I think encapsulating another ESP / GRE (IPSEC/GRE tunnel on top of your current IPSEC tunnel) is the only solution.
I have created a LAB for this .
And simulate the issue with the following configuration on ISP router:
route-map MTU-DROP permit 10
 match length 853 872
 set interface Null0
route-map MTU-DROP permit 20
interface range e0/0,e0/1
 ip policy route-map MTU-DROP
Simulating your existing IPSEC tunnel (i assume it is a VTI tunnel first)
RemoteSite#sh run | s crypto
crypto isakmp policy 10
 encr aes
 authentication pre-share
 group 2
crypto isakmp key CHALLENGE-ACCEPTED address 0.0.0.0
crypto ipsec transform-set TS esp-aes esp-sha-hmac
 mode transport
crypto ipsec profile BASE_VPN
 set transform-set TS
RemoteSite#sh run interface t0
interface Tunnel0
description base VPN tunnel
ip address 172.16.0.2 255.255.255.252
tunnel source Ethernet0/0
tunnel mode ipsec ipv4
tunnel destination 1.1.1.1
tunnel protection ipsec profile BASE_VPN
end
And Data centre side:
DataCentre#sh run | s crypto
 encr aes
 group 2
 mode transport
DataCentre#sh run int t0
interface Tunnel0
ip address 172.16.0.1 255.255.255.252
tunnel destination 2.2.2.2
end
So, the ESP & IPSEC header are around 66 Bytes, so the packet (before encapsulation) with around 787 Byte  will be dropped.
RemoteSite#ping 10.1.0.1 so lo0 size 787
Sending 5, 790-byte ICMP Echos to 10.1.0.1, timeout is 2 seconds:
Packet sent with a source address of 10.2.0.1
Since the gap between 853 - 872 is just about 20 Bytes. Any kind of encapsulation (e.g. GRE / IPSEC) could easily increase the overhead > 20 Bytes.
To address this, we first build another IPSEC tunnel on top the existing tunnel.
DataCentre# sh run | s crypto.*OVERLAY|interface Tunnel100
crypto ipsec profile OVERLAY_VPN
interface Tunnel100
 description overlay VPN tunnel
 ip address 172.31.0.1 255.255.255.252
 tunnel source Tunnel0
 tunnel destination 172.16.0.2
 tunnel protection ipsec profile OVERLAY_VPN
end
Same on the Remote Site Router:
RemoteSite# sh run | s crypto.*OVERLAY|interface Tunnel100
interface Tunnel100
 ip address 172.31.0.2 255.255.255.252
 tunnel destination 172.16.0.1
Create a PBR on both side:
ip local policy route-map PBR
interface e0/1
ip policy route-map PBR
route-map PBR permit 10 match ip address CROSS_SITE_TRAFFIC match length 787 807 set ip next-hop 172.31.0.1
Then, It will successfully migration with the MTU problem.
RemoteSite#ping 10.1.0.1 so lo0 size 790 re 1
Sending 1, 790-byte ICMP Echos to 10.1.0.1, timeout is 2 seconds:
*Jan  7 16:38:37.504: IP: s=10.2.0.1 (local), d=10.1.0.1 (Tunnel100), len 790, local feature, Policy Routing(3), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Jan  7 16:38:37.504: IP: s=10.2.0.1 (local), d=10.1.0.1 (Tunnel100), len 790, sending
*Jan  7 16:38:37.504: IP: s=10.2.0.1 (local), d=10.1.0.1 (Tunnel100), len 790, post-encap feature, IPSEC Post-encap output classification(16), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Jan  7 16:38:37.504: IP: s=10.2.0.1 (local), d=10.1.0.1 (Tunnel100), len 790, sending full packet
*Jan  7 16:38:37.518: IP: s=172.16.0.2 (local), d=172.16.0.1 (Tunnel0), g=172.16.0.1, len 856, forward
*Jan  7 16:38:37.518: IP: s=172.16.0.2 (local), d=172.16.0.1 (Tunnel0), len 856, post-encap feature, IPSEC Post-encap output classification(16), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Jan  7 16:38:37.518: IP: s=172.16.0.2 (local), d=172.16.0.1 (Tunnel0), len 856, sending full packet
*Jan  7 16:38:37.518: IP: s=2.2.2.2 (local), d=1.1.1.1 (Ethernet0/0), g=2.2.2.254, len 920, forward
*Jan  7 16:38:37.518: IP: s=2.2.2.2 (local), d=1.1.1.1 (Ethernet0/0), len 920, sending full packet.
Yes, it look stupid. Just for fun, I would not using it on production environment which making everything become complicated.
6 Replies 6
ngkin2010
Level 7
Level 7
 set interface Null0
 encr aes
 group 2
 mode transport
interface Tunnel0
end
 encr aes
 group 2
 mode transport
interface Tunnel0
end
interface Tunnel100
end
interface Tunnel100
interface e0/1
Hi Sir (Ngkin2010),
Thank you for assisting with this issue! Really appreciate it. SP doesn’t use Cisco infrastructure, has too many customers and thus expect this type of issue to become mainstream in the near future.
Your idea looks promising!!! - I’ll need to incorporate your config snip-let into a lab-prod setup and test. Be in touch shortly.
Again THANK YOU for your efforts.
Frank
@ngkin2010
+5 elagant solution
Kind Regards
Paul
Hi ngkin2010
Thanks again for your support in this issue.
SP indicated they swapped out some of their infrastructure and magically this issue disappeared. Although we didn't get a chance to implement your solution in our production net, I feel it would have worked. Lab efforts were well-on-the-way.
Thanks again
Frank
since you are asking for creative solutions, you also might want to try the below. This would basically compress all packets sized between 853 and 872. I don't know if the compression pushes the size below 853, that is what you would need to test in a real environment:
class-map match-all FRAG
match packet length min 853 max 872
policy-map MTU
 class FRAG
  compress header ip
 class class-default
  fair-queue
interface GigabitEthernet0/0/0
service-policy output MTU
Hi Georg,
Thanks for assisting. I didn't think of your idea before you presented it but I would have attempted if I had more time.
Frank
