Crypto lifetime question
whiteford
Hi, I have a few VPN's connected to my Cisco Concentrator and ASA. The thing is I have never set the life time on the tunnel on the regional sites configs (877's, 1841's), althought on the ASA and Concentrator I have.
What problem's would this create and should I set this?
e.g. Set security-association lifetime seconds 28800
smahbub
Level 6
Level 6
To override the global lifetime value for a particular crypto map entry, which is used when negotiating IP Security security associations,the "set security-association lifetime" command is used in crypto map configuration mode.
Command Syntax:
set security-association lifetime {seconds seconds | kilobytes kilobytes}
For more details about this lifetime settings refer :
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_s2.html#wp1012639
