EIGRP per destination (and per packet for FTP)?
ANCPARCELS
I am currently thinking about using load balancing on two EIGRP enabled links. I don't want to use per packet LB.
The problem I have is that I would like to double my throughput for FTP traffic to a specific destination. So I want to use per packet for FTP. Is there any way this can be done? Can I enable PBR over the EIGRP load balancing?
Richard Burts
Iain
I do not believe that there is any way to change the load sharing method per transport protocol.
You certainly can configure PBR but it does not have any effect on the load balancing method.
Rick
Rick
