CSCtx63716 - Trace back seen @ cmfib_lc_process_entry
HU XU
Hi Can anyone here give me some brief about the bug (CSCtx63716) in 7609S release 15.2(2)S. I haven't found any proper information from Cisco Bug Search Tool what could cause it and what is this about. Is this about and related to some multicast configuration on router and can be invoked only if there is something related to multicast configuration.
InayathUlla Sharieff
Hi HU,
Here is some info for you:-
Router crashes on unconfigurin ip multicast-routing with p2mp-te , gremvpn, mldpmmvpn configurations on the box.
Inayath
Hi Inayat,
Thanks for the reply. u meant to say upon configuring ip multicast routing?
Not configuring its reverse while removing the config.
Inayath
*Plz dont forget to rate the usefull posts
