cTCP not supported by ASR 1001?
tiwang
Level 3
Level 3
Hi out there
We have bought a couple of the ASR VPN bundle with ASR 1001 - but when we started to configure them I got a bit surprised because it looks as if the ASR 1001 doesn't support cTCP which we use in EZVPN - can some out there confirm that the ASR 1001 doesn't support cTCP ?
Here is a little output from it:
Router#sh ver
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.1(3)S, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 22:44 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2011 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are licensed under the GNU General Public License ("GPL") Version 2.0. The software code licensed under GPL Version 2.0 is free software that comes with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such GPL code under the terms of GPL Version 2.0. For more details, see the documentation or "License Notice" file accompanying the IOS-XE software, or the applicable URL provided on the flyer accompanying the IOS-XE software.
ROM: IOS-XE ROMMON
Router uptime is 3 minutes
Uptime for this control processor is 4 minutes System returned to ROM by reload at 23:12:34 UTC Fri Dec 16 2011 System image file is "bootflash:asr1001-universalk9.03.04.00.S.151-3.S.bin"
Last reload reason: Reload Command
This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
If you require further assistance please contact us by sending email to export@cisco.com.
License Info:
License UDI:
Device# PID                    SN                     UDI
*0     ASR1001                 JAE155003BK             ASR1001:JAE155003BK
License Package Information for Module:'asr1001'
Module name   Image level         Pri   Config Valid license
asr1001       adventerprise       1     NO     adventerprise
             advipservices       2     NO     advipservices
             ipbase               3     NO     ipbase
Module name   Current Level       Reboot Level
asr1001       adventerprise       adventerprise
cisco ASR1001 (1RU) processor with 1189088K/6147K bytes of memory.
9 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7782399K bytes of eUSB flash at bootflash:.
Router#
Nicholas Carrieri
This feature is not currently supported and not yet in the roadmap.  If there is a business case for this, please contact your local SE or AM to have them engage the BU for support.
Nicholas Carrieri
hi again
thanks for the reply - we have during the last year get used to not to have this facility avalibly and doesn't use it any more
