custom nbar rule on Cisco ISR1k
mario.jost
Level 3
Level 3
We have following device:
roTRO31#show version | include ^cisco
cisco C1113-8PLTEEA (1RU) processor with 1398091K/6147K bytes of memory.
roTRO31#show license all | include ^Cisco 1100
Cisco 1100 Series with 8 LAN Ports, Security License (ISR_1100_8P_Security):
Cisco 1100 Series with 8 LAN Ports, 200 Mbps IPSEC Throughput License (ISR_1100_8P_IPSEC_Throughput_200Mbps):
roTRO31#show version | include image
System image file is "bootflash:c1100-universalk9.16.12.04.SPA.bin"
But we cant create a custom NBAR rule:
roTRO31(config)#ip nbar ?
http-services Enable HTTP services (URL to use is /flash/nbar2/home.html)
protocol-pack Protocol Pack
This feature is even supported on Catalyst 9200 switches now. Is there a different syntax for this feature?
you need the application experience license in order to have support for NBAR.
SL-1100-8P-APP(=)
pieterh
version: 16.12.04 -> you may need to add the NBAR protocol pack ?
NBAR2 Protocol Pack Library - Cisco
There is already a protocol pack installed on the router:
roTRO31#show ip nbar protocol-pack active
Active Protocol Pack:
  Name:                          Standard Protocol Pack
  Version:                       43.0
  Publisher:                     Cisco Systems Inc.
  NBAR Engine Version:           37
  State:                         Active
SL-1100-8P-APP(=)
