Customizing the Authentication Proxy Web Pages on a router
smailag00
Router :cisco 2901 with securityk9 licence
I used this manual :
http://cisco.sitecelerate.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SY/configuration/guide/web_authentication.html#wp1083487
Im traying to change de login page but the commande dosen't work :
ip admission proxy http login page file disk1:login.htm
This is what I see when I type
(config)#ip admission ?
  absolute-timer      Absolute Timeout in minutes
  auth-proxy-audit    Authentication Proxy Auditing
  auth-proxy-banner   Authentication Proxy Banner
  http                Configure maximum HTTP process
  inactivity-timer    Inactivity Timeout in minutes
  init-state-timer    Init State Timeout in minutes
  max-login-attempts  Max Login attempts per user
  max-nodata-conns    Max TCP NODATA Connections
  name                Specify an Authentication/Admission Rule
  ratelimit           Session Ratelimit
  source-interface    IP Admission Source Interface
  watch-list          Watch-list
Seems like its missing the 'ip admission proxy'  command
so are there other commands that can help me to change the login page of the router proxy?
thanks
smailag00
any idea please
