Datatransfer with Nexus 5548UP over two Vlan's very slow
I have a problem with my Nexus 5548UP.
The data transfer between 2 Vlan's is very slow.
Data transfer in same vlan's is ok.
Have installed a L3 card and a LAN_ENTERPRISE_LICENSE
Inter-Vlan routing works.
See pictures:
Here is a PC in vlan 30 with 10Gbit SFP+ on the Nexus
and the other PC in Vlan 100 on a Catalyst with 1Gbit RJ45
and the other PC also in vlan 30 on a Catalyst with 1Gbit RJ45
How can that be??
23 Replies 23
FTP, SMB, HTTP, any connection.
I am on the trail of the solution.
Remove L3 module and install L2 module
Install NX-OS 5.0(3)N1(1b)
Poweroff the Nexus
Remove L2 and reinstall L3 module.
Install License
Test
just out of curiosity, did that work ?
Almost. The L3 module was designed as a ,,powered-up,,
displayed. Then I installed the LAN_BASE_SERVICE License. After that the module was displayed as ,,OK,,
displayed. After a restart, I get an error. Then the restarts, as soon as the login prompt appears, the Nexus restarts again and again.
I don't know what else to do.
Now the L3 module is finally displayed correctly and more problems are coming.
I have no more desire with the ding...
Does anyone know a solution?
Nexus5K# 2022 Jan 27 17:50:33 Nexus5K %$ VDC-1 %$ %SYSMGR-2-SERVICE_CRASHED: Service "bcm_usd" (PID 4563) hasn't caught signal 11 (core will be saved).
sh licShutdown Ports..
 writing reset reason 16, bcm_usd hap reset
INIT: Sending processes the TERM signal
Jan 27 17:50:40 %LIBSYSMGR-3-SIGTERM_FORCE_EXIT Service "sunnyvale" (PID 4540) is forced exit.
Jan 27 17:50:40 %LIBSYSMGR-3-SIGTERM_FORCE_EXIT Service "statsclient" (PID 4607) is forced exit.
Jan 27 17:50:40 %STP-2-PROFILE SIGNAL Handler:: crossed (0 secs), elapsed (0 secs 1 usecs), usr (0 secs  0 usecs), sys (0 secs 0 usecs) :
syslog[4589]: ERROR, mts_send failed, ERROR = -1, ERRNO = 9
what is the part number for the layer 3 daughter card ? I think there is a version 1 and 2...
Version 2
not sure how you exactly swapped the module, but I assume you powered the switch down first ?
-->  For the Layer 3 GEMs (N55-M160L3 and N55-M160L3-V2) in the Cisco Nexus 5596UP switch, you must power down the switch first. These expansion modules are not hot swappable.
Yes, i powered down first. I know that.
these errors you see might as well indicate a hardware failure. I guess you don't have another L3 module available.
The entire 'issue' could be caused by faulty hardware. Is this a new module, did this ever work properly before ?
ebay. thats says it all.
Ohje..
