DDNS issue, DDNS not updating
Aqe@2016
I have configured Dyn DNS on my Cisco 1921 router (15.3(3)M3) but it is not updating the host-name. I used debug command too to see the DDNS updates but no update or information shown in response to debug ip ddns update command. Can anyone please suggest what is missing in following configuration?
BR-RTR#show runn
Building configuration...
Current configuration : 8336 bytes
! Last configuration change at 10:25:57 UTC Tue Feb 9 2016 by pilot1
version 15.3
hostname BR-RTR
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$PGMm$.ARlNw3FeDyBc0033Fklf1
no aaa new-model
ip dhcp excluded-address 192.168.206.1 192.168.206.100
ip dhcp excluded-address 192.168.206.200 192.168.206.254
ip dhcp pool BR-RTR
network 192.168.206.0 255.255.255.0
default-router 192.168.206.1
dns-server 8.8.8.8 8.8.4.4
ip domain name hq.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip ddns update method MYDYN
HTTP
add http://EmailID:Password@members.dyndns.org/nic/update?system=dyndns&hostname=mydomain.dyndns.org&myip=MYWANIP
interval maximum 2 0 0 0
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-1724857321
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1724857321
revocation-check none
rsakeypair TP-self-signed-1724857321
crypto pki certificate chain TP-self-signed-1724857321
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31373234 38353733 3231301E 170D3134 31313134 31393539
31315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37323438
35373332 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100BCEA D2FEE707 C4B0C4C6 6C604A08 82F79EB8 D470A9BA E5C3DD0B F0D6A335
4C33ECDA C6C8C0A7 A8F1C66B 8C07E90F C11D9EAC 6C062044 B19F5056 5BA0ACC5
DE8968FB 6847E723 81C14BBB 65D7B8AD 08988C33 19D37355 4ABD997E 86D635ED
61C04F4E 77407E1B 68C98D28 47FF95F6 CF2E5052 6E1D1846 F0A264FE 45EC384F
C7050203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14C44FAA 91D904CA B7649917 DD82FF4F 252AA380 35301D06
03551D0E 04160414 C44FAA91 D904CAB7 649917DD 82FF4F25 2AA38035 300D0609
2A864886 F70D0101 05050003 818100AF C998BE34 B2279F5A 60A7349B 80F2E2CC
31D56281 92FD8E56 C6BBB14F 7BCD0479 6BFE91BC 23315B32 A2057AFD 44E7E490
7CB9E67C 4650B4E5 B51EE0EC 85199D11 C6D52B75 8095F719 D373FC43 EF052098
741247D6 00CF278E 70B1EC23 F4B71E7E 81383E20 DD350EB5 5B9F03A7 E91DEBB3
220AA6FD 922ED672 92E9D359 9F53B9
quit
license udi pid CISCO1921/K9 sn abcdefghij
username admin privilege 15 secret 5 $secret/
redundancy
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key cisco123 address HO_WAN_IP
crypto isakmp key cisco123 address JAD-WAN-IP
crypto isakmp key cisco123 hostname hooffice.dyndns.org
crypto ipsec transform-set VPN esp-3des esp-md5-hmac
mode tunnel
crypto ipsec profile HO
set security-association lifetime days 7
crypto map CMAP 10 ipsec-isakmp
set peer HO_WAN_IP
set transform-set VPN
match address JADC
reverse-route
crypto map CMAP 20 ipsec-isakmp
set peer JAD-WAN-IP
match address HO
reverse-route
crypto map CMAP 30 ipsec-isakmp
set peer hooffice.dyndns.org dynamic
set security-association lifetime seconds 86400
match address HO
reverse-route
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ***WAN-INTERFACE***
no ip address
ip tcp adjust-mss 1412
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
description ***LAN-INTERFACE***
ip address 192.168.206.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface Dialer1
ip ddns update hostname mydomain.dyndns.org
ip ddns update MYDYN host mydomain.dyndns.org
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname usename
ppp chap password 0 pass
ppp pap sent-username username password 0 pass
ppp ipcp dns request
crypto map CMAP
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source route-map NONAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.6.0 255.255.255.0 JAD-WAN-IP
ip access-list extended HO
permit ip 192.168.206.0 0.0.0.255 192.168.6.0 0.0.0.255
permit ip 192.168.206.0 0.0.0.255 192.168.5.0 0.0.0.255
permit ip 192.168.206.0 0.0.0.255 172.16.1.0 0.0.0.255
ip access-list extended JADC
permit ip 192.168.206.0 0.0.0.255 10.1.2.0 0.0.0.255
permit ip 192.168.206.0 0.0.0.255 10.1.3.0 0.0.0.255
permit ip 192.168.206.0 0.0.0.255 10.1.4.0 0.0.0.255
ip access-list extended NONAT
deny ip 192.168.206.0 0.0.0.255 10.1.2.0 0.0.0.255
deny ip 192.168.206.0 0.0.0.255 10.1.3.0 0.0.0.255
deny ip 192.168.206.0 0.0.0.255 10.1.4.0 0.0.0.255
deny ip 192.168.206.0 0.0.0.255 192.168.6.0 0.0.0.255
deny ip 192.168.206.0 0.0.0.255 192.168.5.0 0.0.0.255
deny ip 192.168.206.0 0.0.0.255 172.16.1.0 0.0.0.255
deny ip 192.168.206.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 192.168.206.0 0.0.0.255 any
permit ip 192.168.206.0 0.0.0.255 192.168.0.0 0.0.0.255
ip sla auto discovery
ip sla 3
icmp-echo 192.168.0.254 source-ip 192.168.206.1
ip sla schedule 3 life forever start-time now
ip sla 10
icmp-echo 172.16.1.254 source-ip 192.168.206.1
ip sla schedule 10 life forever start-time now
dialer-list 1 protocol ip permit
route-map NONAT permit 10
match ip address NONAT
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
18 Replies 18
Cliff Campbell
If your EmailID includes the @character you need to either enclose it in brackets [user@example.com]:[Password]@members... OR replace the @ with %40 user%40example.com:Password@members...  Either will work.
MYWANIP should also probably be <a> to make it truly dynamic.  This variable will be replaced with the interface IP when it is run. Also, you can make the statement read hostname=<h> and that'll be replaced as well.
I use OpenDNS so I can't tell you if the rest is correct.  I know that I have to use https which comes with another set of challenges (I have to import a cert).   Provided the URL you are using is correct this should work for you.
i have the same issue. there is my config:
ip ddns update method dyndns
HTTP
add http://username:password@members.dyndns.org/nic/updatesystem=dyndns&hostname=myname.dyndns.org&myip=<a>
interval maximum 1 0 0 0
interface Dialer0
description VDSL TELEKOM
ip ddns update hostname myname.dyndns.org
ip ddns update dyndns
show ip ddns update
Dynamic DNS Update on Dialer0:
  Update Method Name            Update Destination
  dyndns                        not available
Debug shows nothing. What i did wrong?
Cisco ISR 886VA, Version 15.3(3)M6, RELEASE SOFTWARE (fc1)
it looks like you are missing the '?' question mark in the URL:
hostname Router_DDNS
ip domain name dyndns.org
HTTP
add http://username:password@members.dyndns.org/nic/update?system=dyndns&hostname=myname.dyndns.org&myip=<a>
interface Dialer0
Press ctrl + V, then type the  '?'
wow, i really don't have "?" because I can't type it:
gate1(DDNS-HTTP)#add http://username:password@members.dyndns.org/nic/update?
WORD
IOS behaves like I ask for the next command...
press Ctrl + V, you can then enter the ?
done. but it still doesn't work:
 HTTP
show ip ddns update
The syntax still doesn't look right. Try the below:
add http://username:password@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
 HTTP
interface Dialer0
no ip redirects
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no keepalive
ppp authentication pap callin
ppp pap sent-username ***********************@t-online.de password 7 *********************
ppp ipcp mask request
ppp ipcp route default
no cdp enable
show ip ddns update
the Cisco's hostname is not the same as the registered name with DynDNS.ORG.
rename your router to the name you registered with DynDns.
HTTP
add http://user:password@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
is it now the same as before?
nothing was changed.
done, no changes.
Odd...
an you post the full configuration of the router ?
I meant the full output of 'show run'...
Current configuration : 3633 bytes
! Last configuration change at 17:13:35 CET Fri Jan 5 2018 by user1
! NVRAM config last updated at 17:13:36 CET Fri Jan 5 2018 by user1
version 15.3
service password-encryption
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 password3
aaa new-model
aaa session-id common
clock timezone CET 1 0
ip domain name my.ad.domain
 HTTP
ip cef
no ipv6 cef
license udi pid C886VA-K9 sn FCZ2044B08C
username user1 privilege 15 secret 5 password1
username user2 privilege 15 secret 5 password2
controller VDSL 0
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 pvc 1/32
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface Ethernet0
 no ip address
interface Ethernet0.7
 description VDSL Internet Verbindung - VLAN 7 tagged
 encapsulation dot1Q 7
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 description LAN
 no ip address
 duplex full
interface Vlan1
 description LAN
 ip address 10.254.1.1 255.255.255.0
 ip flow ingress
 ip nat inside
interface Dialer0
 no ip redirects
 no ip proxy-arp
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 no keepalive
 ppp pap sent-username XXXXXXXXXXXXXXXXXXXXXXXXXXX@t-online.de password 7 ----------------
 no cdp enable
no ip http server
no ip http secure-server
ip flow-export version 9
ip flow-top-talkers
 top 10
 sort-by bytes
ip nat inside source list 101 interface Dialer0 overload
access-list 22 permit 10.254.1.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 10.254.1.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 password 7 ------------------------
 no modem enable
line aux 0
line vty 0 4
 access-class 22 in
 exec-timeout 30 0
 logging synchronous
 transport input ssh
line vty 5 189
 exec-timeout 30 0
 logging synchronous
 transport input ssh
ntp server 10.254.1.9
end
