11-29-2019 06:02 AM
Solved! Go to Solution.
12-03-2019 01:49 AM
post your Packet Tracer project (.pkt) file here as a zipped attachment...
12-03-2019 03:08 AM
here is the thing: Packet Tracer is a simulator with only a limited set of commands. On 'real' routers, you could use IP SLAs to achieve failover. That would look like below. If the main default route is down, the secondary default route would kick in. Unfortunately, Packet Tracer does not support that. Your other option would be to use a routing protocol such as BGP, and manipulate the metric. In BGP, you could use the weight attribute to prefer one path over the other.
Head_Office
track 1 ip sla 1 reachability
ip sla 1
icmp-echo 8.8.8.8 source-interface Serial0/0/0
frequency 5
ip sla schedule 1 start-time now life forever
ip route 0.0.0.0 0.0.0.0 Serial0/0/0 track 1
ip route 0.0.0.0 0.0.0.0 Serial0/1/0 200
Branch_Office
ip sla 1
frequency 5
Head_Office
router bgp 1
neighbor ISP_1 weight 150
Branch_Office
router bgp 2
12-01-2019 12:14 AM
To all concerned,
It is very clear this thread is school work.
Help the students learn: Post the links to documents and configuration guides.
Please refrain from handing out answers.
12-01-2019 12:38 AM
typically, you would achieve this with IP SLAs or configuring one of the interfaces with the 'backup interface' command. Or you can run a dynamic routing protocol and manipulate the metrics. If possible, post the Packet Tracer project file (.pkt), zip it first, otherwise the system won't let you upload it. Keep in mind that Packet Tracer has only a limited set of commands, and 'real' IOS routers have much more extensive options...
12-03-2019 01:20 AM
please help me, i cant send u file of cisco packet tracer, if possible please make it happen and if possible write down the procedure of it in the file mentioning it step by step, i will be really thank full to u. or if u can share ur email so i can send file on ur email
12-03-2019 01:49 AM
12-03-2019 03:08 AM
Head_Office
ip sla 1
frequency 5
Branch_Office
ip sla 1
frequency 5
Head_Office
router bgp 1
Branch_Office
router bgp 2
12-03-2019 08:15 AM
dear goerg, thanks for your support and urgent prompt, its a really helpful for me the effort u have done for me. im really really greatful to you for your time and support. really appreciated. Thanks.
