default-information originate on address-family multicast vrf
Jérémy
I want use the command "default-information originate" on address-family multicast
But when I put it, the router accept the command but it's not present when I show running configuration
address-family ipv4 multicast vrf VPN1
redistribute connected
neighbor 10.4.4.2 remote-as 65400
neighbor 10.4.4.2 activate
neighbor 10.4.4.2 next-hop-self
exit-address-family
ip route vrf VPN1 0.0.0.0 0.0.0.0 Tunnel1 multicast
Thx
Regards.
Jérémy
Bgp
address
neighbor x.x.x.x default-inf
this command we use
but again if default is missing from routing table then it not work
10 Replies 10
johnlloyd_13
Level 9
Level 9
hi,
try the "show run all" and pipe to match the said command, i.e. "show run all | inc default-information originate"
Hello John,
No result when i use "show run all | inc default-information originate"
are tunnel is in same VRF or in global ?
Tunnel is in same VRF
are you sure?
there is different between the tunnel in vrf and source of tunnel in vrf.
which one you use
are you use under tunnel
ip vrf forwarding ?
show ip route vrf
are you see tunnel ip
are you see default route ?
if you can not see both then the advertise is not happened because of this reason.
The adress-family is use on back to back
I have static routing for tunnel
Nominal :
interface GigabitEthernet0/0/1.4005
encapsulation dot1Q 4005
vrf forwarding VPN1
ip address 10.4.4.1 255.255.255.252
ip pim sparse-mode
no cdp enable
NR-4221-5#sh ip route multicast vrf VPN1
S* 0.0.0.0/0 is directly connected, Tunnel1
Backup :
description --ROCADE--
vrf forwarding VPN1
ip address 10.4.4.2 255.255.255.252
ip pim sparse-mode
NR-4221-2#sh ip route multicast vrf VPN1
S* 0.0.0.0/0 [250/0] via 172.22.4.1, Tunnel1
I assume this is a 4221 router ? What if you configure the command under the router process ?
router bgp 1
--> default-information originate
exit-address-family
Hello Georg,
Yes it's two 4221 routers
This command doesn't work under router process
NR-4221-5(config)#router bgp 65400
NR-4221-5(config-router)#default-?
% Unrecognized command
Bgp
address
this command we use
