Default route propogation in BGP and VRF
awickers
I have just implemented VRF for a MPLS & Internet service on a shared 3845 platform and I have now lost my default route propagation to my remote sites.
Before implementing VRF the default route propagated fine to the remote routers and I had a route of last resort on all of them. After implementing VRF the default route was still on the 3845 but the route of last resort is no longer present on the remote routers.
It is definitely the VRF config causing the problem because as soon as I remove the vrf forwarding command from the subinterface the route of last resort appears on the remote routers, I have searched for a solution on the forum and Cisco web site without any luck. Although I think it may be something to do with routes leaking between the vrf and the global routing table.
VRF config is
ip vrf DIA
description *** DIA VRF Instance ***
rd 3549:2
route-target export 3549:2
route-target import 3549:2
interface GigabitEthernet0/1
description *** Internet Connection ***
ip vrf forwarding DIA
ip address 208.50.120.33 255.255.255.224
no keepalive
arp timeout 1500
interface Serial2/0.518 point-to-point
description ***** Internet Connection ****
bandwidth 12000
ip address 207.138.94.182 255.255.255.252
frame-relay interface-dlci 518
Static route are
0.0.0.0 0.0.0.0 10.1.3.253 (internal interface of firewall)
ip route vrf DIA 0.0.0.0 0.0.0.0 207.138.94.181
ip route vrf DIA 208.50.120.32 255.255.255.224 207.138.94.181
BGP config is
router bgp 64610
no synchronization
bgp log-neighbor-changes
network 10.z.z.z mask 255.255.240.0
redistribute static
neighbor x.x.x.x remote-as 6745
neighbor x.x.x.x ebgp-multihop 4
neighbor x.x.x.x version 4
neighbor y.y.y.y remote-as 3549
eighbor y.y.y.y local-as 64875
neighbor y.y.y.y version 4
neighbor y.y.y.y prefix-list DIA-out out
no auto-summary
address-family ipv4 vrf DIA
neighbor y.y.y.y local-as 64875
neighbor y.y.y.y activate
no synchronization
network 208.50.120.32 mask 255.255.255.224
exit-address-family
Hope someone can help.
Regards Andrew
great !
you have a default route in global pointing at 10.1.3.253 which is connected to GE0/0.
under BGP (IPV4) u redistribute static to our remote sites.
Adding "default-information originate" should propagate a default route to remote sites, regardless of what happens under ur VRF config.
The VRF config as I understand is between u and remote AS for peering.
Sam
19 Replies 19
cisco_lad2004
Level 5
Level 5
Try redistrubuting static under address family + add default information originate command under address family also
Sam
Sam
Can you clarify please because if I understand you correctly this will redistribute the static route within the VRF? This is exactly the opposite of what I want to do.
The default route needs redistribute out to the MPLS cloud and not the vrf DIA.
Regards Andrew
OK, then I misunderstood your requirement.sorry.
do u intend to leak a default route pointing at a VRF withing ur global MPLS cloud ?
Sam
No worries I think it's actually my fault the title of this problem should have been default route redistribution into BGP and not the VRF instance and I think my explanation was not very good so lets try again.
Basically I have a BGP peer with my provider for the MPLS cloud running on one subinterface of a DS3 and a BGP peer running on another subinterface as you can see from the configs.
When I do not have the VRF forwarding on the interfaces the default route 0.0.0.0 0.0.0.0 10.1.3.253 is redistributed via the BGP peer in to the MPLS cloud and out to my remote sites and they end up with a route of last resort.
When I do have the VRF forwarding configured on the 2 internet related interfaces Gi0/1 & S2/0.518 the default route is no longer distributed via BGP to my remote sites and the route of last resort is no longer set on the remote routers which is the problem, it needs to be.
How do I ensure that the default route continues to be distributed to my remote sites via BGP with the VRF forwarding configured and working.
Regards Andrew
are remote sites in a separate VRF or global ?
if they are in separate VRFs u could import and export on route targets between ur Internet VRF and remote sites , but use route map to allow default route only.
ip vrf foo
rd 100:1
export map INTERNET
route-target export 100:1
route-target import 100:1
route-target import 200:1
Sam
They are all in global.
Regards Andrew
from what I can see in the config, u have 4 peering sessions in total.
2 of them in Global, which is ur MPLS and another 2 within address family, ur VPN DIA.
I am suspecting that the route to 10.1.3.253 is no longer in global when you make GE0/1 & S2/0.0518 part of VRF DIA.
can you see an entry for " show IP BGP 10.1.3.253" as well as an entry in global ip route(when interfaces are part of DIA VPN) ?
Sam
Sam
The results of a show IP BGP 10.1.3.253 are as follows
With out VRF forwarding DIA on subinterface s2/0.518
BGP routing table entry for 10.1.0.0/20, version 2
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Advertised to update-groups:
Local
0.0.0.0 from 0.0.0.0 (207.138.94.182)
Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, local, best
and with VRF forwarding DIA on subinterface s2/0.518
Local
Which is really strange as it is the same for both, hope this helps as it is now really confusing me......
Regards Andrew
Andrew
you have a local route for 10.1.3.253 as u are advertising this prefix via BGP ( network 10.z.z.z mask 255.255.240.0).
so lets move on to find out what happens to the actual default route.
how about (in both cases please)
sh ip bgp 0.0.0.0
sh ip route 10.1.3.253
Sam
Sam
without VRF active
sh ip bgp 0.0.0.0
BGP routing table entry for 0.0.0.0/0, version 409
Paths: (1 available, best #1, table Default-IP-Routing-Table, RIB-failure(17))
207.138.94.181 from 207.138.94.181 (67.17.81.143)
Origin IGP, localpref 100, valid, external, best
sh ip bgp 10.1.3.253
Local
with VRF active
sh ip bgp 0.0.0.0
BGP routing table entry for 0.0.0.0/0, version 410
Paths: (1 available, no best path)
Flag: 0x820
Not advertised to any peer
64875 3549
207.138.94.181 (inaccessible) from 207.138.94.181 (67.17.81.143)
Local
Regards Andrew
Sam
I have one more thing to add. I have just found the following issue, when I do a
show ip bgp rib without the VRF forwarding installed I get the following
Network Next Hop RIB-failure RIB-NH Matches
0.0.0.0 207.138.94.181 Higher admin distance n/a
64.215.11.32/30 64.215.11.33 Higher admin distance n/a
But with the VRF forwarding installed I get
From this I think it is implying the network route 0.0.0.0 207.138.94.181 is not being installed in the routing table when the VRF forwarding is not installed. Due to the static default route on the route having a higher administrative distance, BUT when the vrf forwarding is installed the same network is installed in the routing table which again implies it now has a higher administrative value that the statically defined default route on the router. So can I fix this by manipulating the static default routs administrative value or am I barking up the wrong tree.
Regards Andrew
Andrew,
with VRF active
sh ip bgp 0.0.0.0
Flag: 0x820
Not advertised to any peer <<================ this is were it stops it from propagating to ur sites.
64875 3549
Not having the ip route output, my guess is that ur default route points to a next hop that is moved from Global to VRF DIA, and therefore not advertised.
27.138.94.181 is teh other end of S2/0.518 and therefore cannot be expected to be seen in global.
Try adding a static route in global that points to S2/0.518 instead of an ip address only.
effectively, u have to leak ur VRF next hop to global.
Sam
Sam
the show ip route without vrf is as follows
Gateway of last resort is 10.1.3.253 to network 0.0.0.0
Then lots more routes then this one
S* 0.0.0.0/0 [10/0] via 10.1.3.253
the show ip route with VRF is exactly the same
but when I do a show ip route VRF DIA without VRF active I get
sh ip route vrf DIA
Routing Table: DIA
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
208.50.120.0/27 is subnetted, 1 subnets
C 208.50.120.32 is directly connected, GigabitEthernet0/1
and with vrf active I get
Routing Table: DIA
Gateway of last resort is 207.138.94.181 to network 0.0.0.0
207.138.94.0/30 is subnetted, 1 subnets
C 207.138.94.180 is directly connected, Serial2/0.518
B* 0.0.0.0/0 [20/0] via 207.138.94.181, 00:00:11
Which I think proves what you are saying but I want a static route with in global to always point to 10.1.3.252 the insdie interface of our firewall not to s2/0.518
Thanks Andrew
Sam
The last sentance above should read
Which I think proves what you are saying but I want a static route within global to always point to the insdie interface of our firewall 10.1.3.253 not to s2/0.518
Regards Andrew
