Default Route redistribution using EIGRP-BGP and VRFs
spencercook
Hi all.
I'm trying to get a default route published from one side of our network to another.  We have a single EIGRP AS across two geographical areas.  This is joined in the middle by a new device (installed by an outside consultancy, which I've now inherited, and entirely out of my hands other than to fix what doesn't work.)
I've made a mock up in GNS 3 with the details below, but what I'm trying to achieve is for the two "local" side default routes to be published into the "remote" side with high costs for backup/failover.  Once I know this is working, I can fail-over test with our ISP at our gateways.
Note, this mock up doesn't reflect our full organisational ring with multiple VRF's, there's just enough to replicate the center join and re-distribution point with the gateways.
Location 1 - UHND - VRF NORTH
Location 2 - DMH - VRF SOUTH
I can get all the LAN routes to publish and traffic works fine with all devices working (real world and GNS3).  However the one thing I don't seem to be able to get is the default route to publish between UHND and DMH using north/south VRF's.
Here is the layout, with the VSS config's and routing tables.
I can't help thinking I'm overlooking something simple.
Any help much appreciated.
UHND-VSS#sh run
Building configuration...
Current configuration : 1390 bytes
version 12.4
hostname UHND-VSS
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip tcp synwait-time 5
interface FastEthernet0/0
description DMH-VSS
bandwidth 50000
ip address 192.168.0.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
description CDDFT LAN
bandwidth 100000
ip address 10.97.144.67 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
ip address 192.168.192.1 255.255.255.252
duplex auto
speed auto
router eigrp 1
network 10.97.144.0 0.0.0.255
network 192.168.0.0 0.0.0.3
network 192.168.192.0 0.0.0.3
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
route-map DEFAULT-TO-SOUTH permit 10
match ip address prefix-list DEFAULT
set metric 777777
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
UHND-VSS#
UHND-VSS#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.97.144.5 to network 0.0.0.0
192.168.192.0/30 is subnetted, 2 subnets
C 192.168.192.0 is directly connected, FastEthernet1/0
D EX 192.168.192.4
[170/1711616] via 192.168.192.2, 00:43:18, FastEthernet1/0
192.168.193.0/30 is subnetted, 2 subnets
D 192.168.193.0 [90/286720] via 192.168.0.2, 00:43:17, FastEthernet0/0
D EX 192.168.193.4 [170/1739776] via 192.168.0.2, 00:43:17, FastEthernet0/0
10.0.0.0/24 is subnetted, 4 subnets
D 10.97.176.0 [90/286720] via 192.168.0.2, 00:43:17, FastEthernet0/0
D EX 10.117.134.0 [170/1739776] via 192.168.0.2, 00:43:18, FastEthernet0/0
D EX 10.117.133.0
[170/1711616] via 192.168.192.2, 00:43:19, FastEthernet1/0
C 10.97.144.0 is directly connected, FastEthernet0/1
192.168.0.0/30 is subnetted, 2 subnets
C 192.168.0.0 is directly connected, FastEthernet0/0
D 192.168.0.4 [90/284160] via 192.168.0.2, 00:43:20, FastEthernet0/0
D*EX 0.0.0.0/0 [170/261120] via 10.97.144.5, 00:43:21, FastEthernet0/1
DMH-VSS#sh run
Current configuration : 1417 bytes
version 12.4
hostname DMH-VSS
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
description UHND-VSS
bandwidth 1000
ip address 192.168.0.5 255.255.255.252
delay 2000
duplex auto
speed auto
bandwidth 100000
ip address 10.97.176.1 255.255.255.0
duplex auto
speed auto
description LAN
ip address 192.168.193.1 255.255.255.252
duplex auto
speed auto
router eigrp 1
network 10.97.176.0 0.0.0.255
network 192.168.0.4 0.0.0.3
network 192.168.193.0 0.0.0.3
no auto-summary
no ip http server
route-map DEFAULT-TO-NORTH permit 10
set metric 777777
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
DMH-VSS#
DMH-VSS#sh ip route
Gateway of last resort is 10.97.176.5 to network 0.0.0.0
D 192.168.192.0 [90/3100160] via 192.168.0.6, 00:44:47, FastEthernet0/0
D EX 192.168.192.4 [170/3102720] via 192.168.0.6, 00:44:47, FastEthernet0/0
C 192.168.193.0 is directly connected, FastEthernet1/0
D EX 192.168.193.4
[170/1711616] via 192.168.193.2, 00:44:47, FastEthernet1/0
C 10.97.176.0 is directly connected, FastEthernet0/1
D EX 10.117.134.0
[170/1711616] via 192.168.193.2, 00:44:49, FastEthernet1/0
D EX 10.117.133.0 [170/3102720] via 192.168.0.6, 00:44:48, FastEthernet0/0
D 10.97.144.0 [90/3100160] via 192.168.0.6, 00:44:48, FastEthernet0/0
D 192.168.0.0 [90/3097600] via 192.168.0.6, 00:44:48, FastEthernet0/0
C 192.168.0.4 is directly connected, FastEthernet0/0
D*EX 0.0.0.0/0 [170/261120] via 10.97.176.5, 00:30:29, FastEthernet0/1
TF-VSS#sh run
Current configuration : 2747 bytes
version 12.4
hostname TF-VSS
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf LINK
ip vrf NORTH
rd 5:1
route-target export 5:1
route-target import 5:2
ip vrf SOUTH
rd 5:2
route-target export 5:2
route-target import 5:1
no ip domain lookup
archive
log config
hidekeys
ip vrf forwarding NORTH
ip address 192.168.0.2 255.255.255.252
duplex auto
speed auto
ip vrf forwarding SOUTH
ip address 192.168.0.6 255.255.255.252
duplex auto
speed auto
router eigrp 1
auto-summary
address-family ipv4 vrf SOUTH
redistribute bgp 5 metric 1500 10 255 1 1500
network 192.168.0.6 0.0.0.0
no auto-summary
autonomous-system 1
exit-address-family
address-family ipv4 vrf NORTH
network 192.168.0.2 0.0.0.0
no auto-summary
autonomous-system 1
exit-address-family
router bgp 5
no synchronization
bgp log-neighbor-changes
no auto-summary
redistribute connected
redistribute eigrp 1 metric 300 route-map NORTH-EIGRP-BGP
default-information originate
synchronization
bgp redistribute-internal
exit-address-family
redistribute eigrp 1 metric 300 route-map SOUTH-EIGRP-BGP
synchronization
exit-address-family
no ip http server
ip prefix-list DEFAULT seq 5 permit 0.0.0.0/0
ip prefix-list NORTH-EIGRP-BGP seq 10 permit 0.0.0.0/0 le 32
ip prefix-list SOUTH-EIGRP-BGP seq 10 permit 0.0.0.0/0 le 32
route-map SOUTH-EIGRP-BGP permit 10
set metric 5000 1000000 255 150 1500
route-map SOUTH-EIGRP-BGP permit 20
match ip address prefix-list SOUTH-EIGRP-BGP
set metric 1000000 10 155 1 1500
route-map SOUTH-EIGRP-BGP deny 100
route-map NORTH-EIGRP-BGP permit 10
route-map NORTH-EIGRP-BGP permit 20
match ip address prefix-list NORTH-EIGRP-BGP
route-map NORTH-EIGRP-BGP deny 100
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
TF-VSS#sh ip route
Gateway of last resort is not set
TF-VSS#sh ip route vrf NORTH
Routing Table: NORTH
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
D 192.168.192.0 [90/284160] via 192.168.0.1, 00:46:24, FastEthernet0/0
D EX 192.168.192.4 [170/1737216] via 192.168.0.1, 00:46:24, FastEthernet0/0
B 192.168.193.0
[20/284160] via 192.168.0.5 (SOUTH), 01:08:03, FastEthernet0/1
B 192.168.193.4
[20/1737216] via 192.168.0.5 (SOUTH), 01:08:03, FastEthernet0/1
B 10.97.176.0
[20/284160] via 192.168.0.5 (SOUTH), 01:08:04, FastEthernet0/1
B 10.117.134.0
[20/1737216] via 192.168.0.5 (SOUTH), 01:08:05, FastEthernet0/1
D EX 10.117.133.0 [170/1737216] via 192.168.0.1, 00:46:26, FastEthernet0/0
D 10.97.144.0 [90/284160] via 192.168.0.1, 00:46:26, FastEthernet0/0
B 192.168.0.4 is directly connected, 01:24:20, FastEthernet0/1
D*EX 0.0.0.0/0 [170/286720] via 192.168.0.1, 00:46:26, FastEthernet0/0
TF-VSS#sh ip route vrf SOUTH
Routing Table: SOUTH
Gateway of last resort is 192.168.0.5 to network 0.0.0.0
B 192.168.192.0
[20/284160] via 192.168.0.1 (NORTH), 01:07:54, FastEthernet0/0
B 192.168.192.4
[20/1737216] via 192.168.0.1 (NORTH), 01:07:39, FastEthernet0/0
D 192.168.193.0 [90/284160] via 192.168.0.5, 00:46:41, FastEthernet0/1
D EX 192.168.193.4 [170/1737216] via 192.168.0.5, 00:46:41, FastEthernet0/1
D 10.97.176.0 [90/284160] via 192.168.0.5, 00:46:42, FastEthernet0/1
D EX 10.117.134.0 [170/1737216] via 192.168.0.5, 00:46:42, FastEthernet0/1
B 10.117.133.0
[20/1737216] via 192.168.0.1 (NORTH), 01:07:41, FastEthernet0/0
B 10.97.144.0
[20/284160] via 192.168.0.1 (NORTH), 01:07:56, FastEthernet0/0
B 192.168.0.0 is directly connected, 01:24:27, FastEthernet0/0
C 192.168.0.4 is directly connected, FastEthernet0/1
D*EX 0.0.0.0/0 [170/286720] via 192.168.0.5, 00:32:25, FastEthernet0/1
Why does TF-VSS has two legs in two different VRF while you have mixed both VRF routing tables?
