Default routing not working
ashararitesh
Hello all,
Default routing not working in WS-C2960X-24TS-L, as below configuration.
Switch Ports Model SW Version SW Image
* 1 30 WS-C2960X-24TS-L 15.2(7)E0a C2960X-UNIVERSALK9-M
Configuration register is 0xF
Switch#show run
Building configuration...
Current configuration : 1867 bytes
! Last configuration change at 09:40:13 UTC Mon Mar 21 2005
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960x-24ts-l
ip routing
spanning-tree mode rapid-pvst
interface FastEthernet0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
switchport access vlan 20
switchport mode access
interface GigabitEthernet1/0/2
switchport access vlan 100
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
shutdown
interface Vlan20
ip address 10.0.20.36 255.255.255.0
interface Vlan100
ip address 192.168.100.1 255.255.255.0
ip default-gateway 10.0.20.251
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.0.20.251
line con 0
line vty 5 15
end
Switch#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 266/269/273 ms
Switch#
Note : Inter vlan routing successfully but vlan 100 internet not working
15 Replies 15
mlund
Level 7
Level 7
As noted by the others, it is your sonic firewall that is not correctly configured.
When pc sends traceroute to 4.2.2.2, it sends 3 packets with ttl=1, that means the swithch have to drop the packets and sends a icmp ttl expired back to the pc. The pc then sends 3 packets with ttl=2. The switch looks in the routingtable and forwards the packet towards the sonic firewall, it also decrement the ttl value from 2 to 1. The packets arrive to the sonic that realize that the ttl is to expire, so it will look in its routingtable to see where 192.168.100.0 net is, so it can send the icmp ttl expire.
It probably finds that there is no such routingentry and will therefore send the packet too its default, wich is upstream to the provider.
The same scenario if you ping 4.2.2.2 from pc. It sends packet to switch, the switch sends to sonic, sonic sends to provider, when answer comes back there is no routingentry for 192.168.100.0.
The above is for routing part.
On top of that you also need to have nat configured for 192.168.100.0.
/Mikael
