Defaulting a 2950 or 3550 Switch
adamgutierrez
Is there a way/command to bring the switch back to it's factory default programming? I have a set of switches I would like to start over from scratch with. Would a startup config and vlan.dat from a new switch be all I need to completely start over, or would I still be missing something?
Adam
Collin Clark
To rease the config-
'write erase'
To also remove the vlans-
'del flash:vlan.dat'
Then reload
Thanks a bunch!!
Glad to help and don't forget to rate!
