Define Bandwidth For 10 Gbps Interface
zekebashi
Level 8
Level 8
2 Accepted Solutions
Georg Pauwen
Two other options would be policing and generic traffic shaping:
Policing
policy-map LIMIT_BW
 class class-default
  police rate 200000000
interface Ethernet5/1.100
 service-policy input LIMIT_BW
 service-policy output LIMIT_BW
interface Ethernet5/1.101
interface Ethernet5/1.102
interface Ethernet5/1.103
interface Ethernet5/1.104
Generic Traffic Shaping
 traffic-shape rate 200000000 3750000 7500000
policing is rather harsh, meaning that traffic that exceeds the rate will be dropped. Depending on your platform, there might be options to specify exceed actions...
5 Replies 5
Georg Pauwen
you could simply rate limit the input and output on each subinterface. In the example below, each subinterface would get 2GB inbound and outbound:
rate-limit input 2000000000 375000000 750000000 conform-action transmit exceed-action drop
rate-limit output 2000000000 375000000 750000000 conform-action transmit exceed-action drop
Georg Pauwen
Policing
policy-map LIMIT_BW
 class class-default
Hi Gpauwen
Thank you for this great material. In relation to the Policing approach, what's the action that will be taken if the sub-interfaces exceeded the BW limit specified?
Best, ~zK
Thanks for this helpful info.
Much appreciated!
Best,   ~sK
