04-11-2005 12:56 AM - edited 03-03-2019 09:15 AM
Is it possible to define a range of ports, when configuring PAT to allow external Users access to an Internal Server ?
E.g. I want anyone hitting the external interface address on ports 10000-20000 to be forwarded to an inside IP address on the same ports ? Can this be done using only 1 command line ?
Regards \\ Naman
04-11-2005 05:08 AM
Not sure, but try this out.
ip nat inside source static 10.1.1.1 127.0.0.1 route-map WHAT!
access-list 106 permit tcp any any range 10000 20000
access-list 106 permit tcp any range 10000 20000 any
route-map WHAT! permit 10
match ip address 106
04-11-2005 07:37 AM
Thanks for the pointer. Will give it a try.
\\ Naman
