Definition Of Feasible Distance In EIGRP Convergence
Mr-World-Wide
hi
i have some problems with understanding  the definition of feasible distance in EIGRP Convergence
 this book "CCNP Routing and Switching ROUTE 300-101 Official Cert Guide" said:
<<<Feasible Distance (FD): Integer metric for the route, from the local router’s perspective, used
by the local router to choose the best route for that prefix.>>>>
But my teacher said the book definition is not correct for feasible distance
 this definition is for computed distance
and he said that  there is a difference between these two definitions
for example
there is 2 path for R1 to reach subnet 10.1.0.0./8
from R2 by computed distance 435200 and reported distance 409600
from R3 by computed distance 448512 and reported distance 422912
and feasible distance is 435200
and the second link is feasible successor because Reported Distance  is less than Computed Distance of best route
then he changed the delay of the Successor interface from 1000 to 500
now computed distance and feasible distance for successor became 422400
and again he changed the delay of interface to 1000
but this time the computed distance became 435200 But the feasible distance remained the same as before "22400"
And he said the correct definition of Feasible Distance is:
The best or minimum Metric that can be , NOT the best or minimum metric that it is now
Is this definition is correct????????
2 Accepted Solutions
Peter Paluch
Your teacher is correct, and I appreciate him very much for being so precise! If the textbook you referenced claims that the Feasible Distance is the current best metric toward a destination, it is sadly not entirely precise.
Feasible Distance is the lowest distance to the destination experienced since the last time the route went from Active to Passive state. Put differently, the Feasible Distance is the historical record of how closest the router was to the destination since the last diffusing computation for the destination has finished. It is indeed not the current best distance - rather, it is a historical record of the smallest distance known since the last Active->Passive transition. Thus, the value of the Feasible Distance can either be the same as the current best distance, or it can be lower (naturally, it can never be higher).
Your teacher was very wise to show you that the Feasible Distance can truly remain at its current value even if the current best distance rises, as long as this distance increase does not cause the router to go Active. The precise rules for this are not relevant at this point but if you wish, I suggest you start another thread about the precise rules of when a EIGRP route becomes Active - that topic is somewhat more extensive to explain.
You should be aware that the myth of "Feasible Distance is the current best distance" is extremely widespread and appears in many official documents as well. For some reason, it has been the common - and wrong - explanation for more than a decade.
Please tell your teacher my compliments! And of course, feel welcome to ask further!
Best regards,
Peter
You are welcome.
I think it will be better to first explain the whole issue from scratch, and then react to your comments.
First, a terminological correction so that we have the individual terms set straight: Terms Successor and Feasible Successor refer to a neighboring router, not to a route. It is incorrect to say "a route is a successor", or "a route is a feasible successor". Correctly, we should say: "this neighboring router is a successor", and "this neighboring router is a feasible successor". Sometimes, terms "successor route" and "feasible successor route" are used instead of more complicated "route through a successor", "route through a feasible successor" statements. However, the one thing holds: successor and feasible successor are neighboring routers, not routes.
Regarding distances in EIGRP, we distinguish between three types of distances EIGRP calculates and keeps track of. Whenever we talk about these distances, we have a particular destination in mind - for every particular destination known to an EIGRP router, an entirely independent calculation of the distances below is performed.
Reported Distance, or RD, is a distance to a particular destination learned from a particular neighboring router. This distance expresses the current best known distance of that neighbor to the destination, or in other words, how far that neighbor is from the destination. An independent RD is kept for each destination and neighbor. If a router has, say, 3 neighbors then for each known destination learned via EIGRP, it will keep 3 independent RD values, one for each neighbor.
Computed Distance, or CD, is a distance to a particular destination through a particular neighboring router. This distance expresses the total distance to the destination through a particular neighbor. Quite logically, CD through a particular neighbor is computed using that neighbor's RD, and the metric of the link between this router and that particular neighbor. If a router has 3 neighbors then for each known destination learned via EIGRP, it will keep 3 independent CD values, one for each neighbor.
Feasible Distance, or FD, as we have discussed already, is a record of the smallest CD for a particular destination ever encountered since the last time this destination went from Active to Passive state. As opposed to RD and CD that are kept for each neighbor to a destination, FD is kept only for the destination - so regardless how many neighbors you have, a router maintains only a single FD value for a particular destination.
To sum up what we have so far, there are three relevant distances in EIGRP to keep in mind:
  • Reported Distance (RD), holding the currently known distance of a particular neighbor to a particular destination
  • Computed Distance (CD), holding the distance to a particular destination through a particular neighbor, computed from that neighbor's RD and the metric of the link toward that neighbor
  • Feasible Distance (FD), holding the lowest known value of the CD toward a particular destination since the last time the destination went from Active to Passive state
Some sources make a huge mistake in that they confuse the CD with the FD, and they assume that the total distance through a particular neighbor is the FD - but this is wrong. Note that this is the same mistake you have posted yourself:
from R2 with FD 14000 and RD 10000
from R3 with FD 16000 and RD 15000
from R4 with FD 17000 and RD 13000
This is not right. Correctly, the table should be labeled differently:
FD = 14000 (lowest currently available and assuming no prior history)
from R2 with CD 14000 and RD 10000
from R3 with CD 16000 and RD 15000
from R4 with CD 17000 and RD 13000
So far so good?
Okay, now, the Feasibility Condition states this:
At any time, any neighbor that, for a particular destination, meets the inequality RD < FD provides a loop-free path to the destination, and will be called the Feasible Successor.
If we loosen up the vocabulary a little and take into account that the RD tells us how close the neighbor is to the destination, and FD tells us how close we have ever been to that destination (remember, it is a historical minimum), then the Feasibility Condition can be rewritten as follows:
At any time, any neighbor that, for a particular destination, is closer to that destination than we have ever been since the last time the destination went from Active to Passive state provides a loop-free path to the destination, and will be called the Feasible Successor.
So, we now know what the Feasibility Condition states - that it is a rule to select paths guaranteed to be loop-free - and we also know that any neighbor that provides such a loop-free path (because it meets the Feasibility Condition) will be called a Feasible Successor.
Now, if that is a Feasible Successor, what is a Successor?
It turns out that the Cisco terminology is a little vague on this point. A Successor is defined as a router that provides the least CD and at the same time meets the Feasibility Condition. Such router could also be called a Feasible Successor because every router meeting the Feasibility Condition is by definition a Feasible Successor, but here, we want to have a special name for a router that not only provides a loop-free path, but also a path that is the cheapest available. So, the name Successor is reserved for those routers that meet the Feasibility Condition and at the same time provide the least CD, while the name Feasible Successor is reserved for those router that meet the Feasibility Condition but whose CD is higher. Feasible Successors always provide a loop-free path, however, they do not provide the least cost path.
For each destination, there always is at least one Successor. There may or may not be any Feasible Successors.
Now, let me requote the example you have posted:
Here, R2 provides the least CD and meets the Feasibility Condition (10000 < 14000), so it will become the Successor. R4 also meets the Feasibility Condition (13000 < 14000) but its CD isn't the lowest available, so R4 is a Feasible Successor.
R3 does not meet the Feasibility Condition and so is neither Successor nor Feasible Successor - it is just a neighbor, but in this particular example, it happens to be a rather special neighbor: If R2 fails, R3 will be providing the least CD but it still won't meet the Feasibility Condition. Notice the dilemma here: If R1 uses R4, it will be using a guaranteed loop-free path but possibly a one that is not the shortest available. On the other hand, R1 is not allowed to use R3 even though it appears to provide a shorter path than R4 if it does not meet the Feasibility Condition.
So what R1 will do now is truly to go Active and send out Queries to find out whether the path through R3 would be looped or loop-free.
Notice that this is again different from what many sources say: It is often said that if the current Successor fails, the router will try to look up Feasible Successor if it has any, and if so, promote it to the new Successor role. In reality, this is not what happens because it would potentially cause a router to remain stuck using a suboptimal path and be happy with it. The real sequence of steps in EIGRP is, in general, this:
  1. After learning about a topology change, update the RD and CD depending on what the topology change is. If a new RD over a neighbor is learned, both the RD and corresponding CD need to be recalculated. If the metric of a link to a neighbor changed, only the CD through that neighbor needs to be recalculated. Loss of a neighbor is represented by setting the RD and CD of all routes through that neighbor to infinity. Adding a neighbor is done by adding that neighbor's RD and resulting CD to each network it advertises.
  2. After processing the information from the topology change as described in the previous step, look up the neighbor providing the least CD.
  3. Using the neighbor identified from the previous step, verify whether it meets the Feasibility Condition.
    If it does not meet the Feasibility Condition, move the network to the Active state and send Queries.
    If it meets the Feasibility Condition, promote it to the new Successor, and if its CD is even lower than the current FD, set the FD to the CD over this new Successor (a new minimum has been found).
So, again, to sum it up, it's simple: Whatever happens in EIGRP, first update the distances and then check whether the neighbor providing the least CD also meets the Feasibility Condition. If it does - hooray! - you've got a Successor! If it does not - oops! - you need to go Active as you cannot be sure whether you can use it but still you absolutely do not want to leave any stone unturned in the search for the least cost path.
This, in general, confirms your teacher's comments. However, definitions are a very sensitive issue as every misquoted word can give the definition a radically different meaning. The definitions you have quoted are not correct, neither one - neither the one from the book, nor the one from your teacher - but I am attributing this to the imprecision in reposting and translating so I am not going to judge based on this one.
You may be also interested in reading the following thread where a similar topic was discussed:
https://supportforums.cisco.com/discussion/11877371/eigrp-successor-and-feasible-successor
Feel welcome to ask further!
Best regards,
Peter
10 Replies 10
Peter Paluch
Best regards,
Peter
thank you so much Mr @Peter Paluch for your great tips
But one more thing
on this book again : CCNP Routing and Switching ROUTE 300-101 Official Cert Guide By KEVIN WALLACE
About the Feasible Successor ,The book says on page 184:
 A router determines whether a route is a feasible successor based on the feasibility condition, defined
as follows:
If a nonsuccessor route’s RD is less than the FD, the route is a feasible successor route.
But My theacher Says:
This definition is wrong.
The correct definition is :
The best route after current successor become Feasible Successor when the reported distance is less than current best successor feasible distance
its mean:
there is 3 path From R1 To network 10.1.0.0/8
the book specifically says:
route Frome R2 become Successor because it has lowest FD that is 14000
and route from R4 become Feasible Successor because it's RD that is 13000 is less than best route's FD that is 14000
My Teacher says
this definition is completely wrong
becuase as in the previous example
route from R4 never become Feasible Distance
becuse its not the best route after current Successor
in the previous example , if the current successor route has faild , the router certainly sends the Query and waiting for reply to ensure that the
other route is loop-free routes
You are welcome.
So far so good?
Best regards,
Peter
Excellent peter!
Kind Regards
Paul
thank you
thank you Peter
that was perfect Mr @Peter Paluch
Indeed this requires further study
However About quote me
I mean CD
It was just a mistake
but I Read more
thank you so much
Flawless and Invaluable Explanation :)
I am little confused.
My understanding:
1. Feasible Distance only changes when EIGRP goes to Active to Passive.
2. Feasible Distance cannot increase. It can only stay or decrease.
3. It is just a historical record how closest the router was to the destination.
Am I right?
Since the FD won't increase until the state toggles to active and back; is that why Cisco does not recommend using the K values for (2) Load and (4) Reliability in the metric calculation?
Hello @btk_1,
Cisco's recommendation not to use load and reliability related K-values in EIGRP boils down to the fact that when they change on an interface, they do not generate an event to EIGRP, and so they do not immediately impact the best path selection. If they did, EIGRP might get unstable - a traffic could be moved to a formerly underutilized link, causing its load (and consequently the metric) to rise and eventually fall back to the original link, starting the whole cycle again.
So even if you enable the K2, K4 and K5, EIGRP will not trigger an update just because the load and/or reliability change. EIGRP only takes a "snapshot" of the momentary reliability and load values when it sends an update (or a query, or a reply) triggered by other events. Hence, the load and reliability metric components are, in practical terms, useless as far as EIGRP is concerned.
Please feel welcome to ask further!
Best regards,
Peter
