how to trunk thought static route ?
Anaphat
VLAN gateway on different switch with access port how to trunk thought static route if it not possible is there a way around it ?
i just get in to  learning networking for two week
stuck on this question for 4 day now  any subject i should look in to?
to be able to answer this question
here the config on the switch
  core switch 1 :
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
no switchport
ip address 172.16.0.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/4
switchport access vlan 60
switchport mode access
switchport nonegotiate
interface Vlan10
mac-address 000a.413d.8101
ip address 192.168.10.1 255.255.255.0
ip helper-address 192.168.40.2
ip access-group Vlan-ACLs in
interface Vlan20
mac-address 000a.413d.8102
ip address 192.168.20.1 255.255.255.0
interface Vlan30
mac-address 000a.413d.8103
ip address 192.168.30.1 255.255.255.0
ip classless
ip route 192.168.40.0 255.255.255.0 172.16.0.2
ip route 192.168.50.0 255.255.255.0 172.16.0.2
ip route 192.168.60.0 255.255.255.0 172.16.0.2
ip flow-export version 9
ip access-list extended Vlan-ACLs
permit tcp any eq www any
deny icmp 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255 echo
permit ip any any
permit icmp any any
core switch 2 :
no switchport
ip address 172.16.0.2 255.255.255.252
duplex auto
speed auto
switchport access vlan 50
switchport access vlan 40
interface Vlan1
no ip address
shutdown
interface Vlan40
mac-address 00d0.5882.e301
ip address 192.168.40.1 255.255.255.0
interface Vlan50
mac-address 00d0.5882.e302
ip address 192.168.50.1 255.255.255.0
interface Vlan60
mac-address 00d0.5882.e303
ip address 192.168.60.1 255.255.255.0
ip classless
ip route 192.168.10.0 255.255.255.0 172.16.0.1
ip route 192.168.20.0 255.255.255.0 172.16.0.1
ip route 192.168.30.0 255.255.255.0 172.16.0.1
ps. thank you in advance for the answer and apology on my broken english
here the file : https://drive.google.com/file/d/1pr5DI7H7qcbIlY7KVO9prL6YzpEbpSkQ/view?usp=sharing
Jon Marshall
Your setup won't work.
Either create the L3 interface (SVI) for vlan 60 on core switch 1 or use a trunk link between core switch 1 and core switch 2 and allow vlan 60.
Jon
5 Replies 5
better share your pkt file as in zip  format
Good luck
KB
what is your pkt version?
Good luck
KB
Cisco packet tracer Version: 8.1.1.0022
Jon Marshall
Jon
