delete vedge config from ISR 1100-4g router
davidexyte
i need to install custom config on a ISR 110-4g router, need to erase the vedge config. i dont have a Vmanage dashboard, need to make it stand alone device with custom config. Tried the reset button with no result. need help.
balaji.bandi
You looking normal IOS XE config, moving from SD-WAN ?
you need to convert cedge to IOS XE
https://www.cisco.com/c/en/us/support/docs/routers/xe-sd-wan-routers/214519-how-to-downgrade-router-running-ios-xr-s.html
BB
