deleting trustpoints from ssl accelerator
adamtroxel
How do I go about deleting trustpoints from my ssl accelerator?
no cry ca trustpoint <tpointname> is how I think it needs to be done.
Just as a quick question...
If I do this - it will not delete any other trustpoints, right? I have about 100 of them all with the same cert authority...
example
authority is geotrust.com
I have these trustpoints
a1
a2
a3
a4
If I give the command no cry ca trustpoint a3 it will delete a3
and leave
a1
a2
a4
correct?
Or is there a better way?
tstanik
Level 5
Level 5
Here is the command description which will help you :
To identify the trustpoints that will be used to validate a certificate during Internet Key Exchange (IKE) authentication, use the ca trust-point command in ISAKMP profile configuration mode.
To remove the trustpoint, use the no form of this command.
ca trust-point trustpoint-name
no ca trust-point trustpoint-name
Syntax Description
trustpoint-name : The trustpoint name as defined in the global configuration.
