DEPLOYMENT OF CISCO ISR 900 ROUTER, C921- 4PLTEGB MODEL
Please my name is Benedict, i have procured a Cisco router ISR 900 series C921-4PLTEGB for failover solution and i want assistance on how to set it up through HTTP management. I am yet to order for an RJ45 to USB CONSOLE cable. I will really appreciate a kind gesture of opinions about implementing this device most especially if i can also be provided with the IP address of this device to be reached through http.
8 Replies 8
pieterh
FAQ: What web-based or GUI tool is available for the 900 Series ISRs?
You can configure and manage the 900 Series ISRs with Cisco Configuration Professional.
The default configuration file assigns an IP address to a LAN interface on the router, and you must configure the PC to be on the same subnet as the router LAN interface. If the router is a fixed-interface model, it is configured as a DHCP server, and the PC must be configured to accept an IP address automatically. If the router can accept modular interfaces, it is not configured as a DHCP server, and you must configure the PC with a static IP address on the same subnet as the router.
If you are lucky you do not need to configure the ip-address
connect your PC to the router only and no other network !!! and check if you received an ip-address for the router (windows-> ipconfig /all, linux ifconfig -a)
in the dhcp information you will find the routers ip address in two fields as dhcp server and as default gateway
Thanks for your response and the heads up.
Will try it and give a feedback when I resume work at my office as I'm currently working from home.
T0mTheCat
Hi Pieterh and Ben, I bought the c921-4P, however I have difficulties setting up thru CLI. I have not much experience in Cisco CLI.
The link Pieterh provide, I cant seem to find the software download in Cisco https://software.cisco.com/download/home
I tried plug directly from my PC to the Router switchport or the WAN, i cant get any DHCP ip unless i set it static.
These are my configuration, hope to get reply from you. Thank you! =D
Current configuration : 2676 bytes
! Last configuration change at 07:46:18 UTC Thu Oct 8 2020
version 15.8
hostname avita_SG
boot-start-marker
boot-end-marker
no aaa new-model
no process cpu extended history
no process cpu autoprofile hog
memory-size iomem 25
ip dhcp excluded-address 192.168.2.2 192.168.2.30
ip dhcp excluded-address 192.168.2.97 192.168.2.101
ip dhcp excluded-address 192.168.9.0
ip dhcp pool vlan 10
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 192.168.2.1 8.8.8.8
ip dhcp pool dpool1
import all
network 10.10.0.0 255.255.255.0
default-router 10.10.10.10
dns-server 192.168.35.2
domain-name cisco.com
ip domain name smallbiz.com
ip name-server 192.168.2.1
ip name-server 192.168.11.12
ip cef
no ipv6 cef
redundancy
no cdp run
interface Loopback0
ip address 200.200.100.1 255.255.255.0
ip nat outside
ip virtual-reassembly in
interface GigabitEthernet0
switchport access vlan 10
switchport mode trunk
no ip address
no cdp enable
interface GigabitEthernet1
no ip address
no cdp enable
interface GigabitEthernet2
no ip address
no cdp enable
interface GigabitEthernet3
no ip address
no cdp enable
interface GigabitEthernet4
ip address 192.168.12.2 255.255.255.0
duplex auto
speed auto
no cdp enable
interface GigabitEthernet5
ip address 192.168.2.3 255.255.255.0
ip nat outside
duplex auto
speed auto
no cdp enable
pppoe enable
pppoe-client dial-pool-number 1
no mop enabled
interface Virtual-Template1
ip unnumbered Loopback0
ip nat outside
interface Vlan1
ip address 192.168.1.4 255.255.255.0
ip nat inside
router eigrp 1009
network 192.168.12.0
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat pool pool1 192.168.1.0 192.168.2.0 netmask 255.255.252.0
ip nat inside source list 1 interface Dialer0 overload
ip route 192.168.2.0 255.255.255.0 10.10.10.2
no service-routing capabilities-manager
access-list 1 permit 0.0.0.0 255.255.255.0
control-plane
end
what does your topology look like ? Is this router directly connected to the Internet, or is there an ISP (modem) on front of your 921 ?
What are your internal networks ?
Hi Georg,
Thanks for getting back!
I manage to sort out thanks to Pieterh, what im missing is VLAN interface
int vlan 10
ip address 192.168.2.1 255.255.255.0
no shutdown
after setting above, my PC could get IP
hope can help someone in the future!
Hi James it would have been better to start a new thread, instead of replying your question to an existing thread
but that sayd....
1) the software can be found using
2) are your DHCP clients connected to vlan10 ports?
- you have a pool ip dhcp pool vlan 10 and a pool dpool1
- you have a client port in vlan 10 like
- but you have no interface vlan10 !  only interface Vlan1
  -> add an interface vlan 10 with ip-address from  192.168.2.1 (the default-router configured in this dhcp options)
      or an interface vlan 10 with ip-address 10.10.10.10  (the default-router configured in that dhcp options)
Hi Pieterh,
Apologize for not creating a new thread, i am so new to this =D
Much appreciate for your reply!
should I create a new thread and redirect it?
1) I tried the link you recommend, i only find 3.5 express, can it work? see attached
2) thanks Pieterh! it worked!
int vlan 10
no shutdown
1) looks like Cisco CP stopped at version 2.8, new versions are only Cisco CP-Express
there is a dependency with the device-model and IOS version on the device
version 2.8 does NOT list the 900-series , 3.5.3 list your model C921-4PLTEGB
-> yes you can use this version,
Downloads Home
Cloud and Systems Management
Routing and Switching Management
Configuration Professional Software
- 2.8
