design help
bluesea2010
Level 5
Level 5
collapsed core architecture  and for TOR for servers
Hi ,
I have the  above  topology,  to access layer is layer 2 and also to TOR switches ( for servers )
in firewall, SVI is configured on the firewall for servers
and for access layer svi is on the core switch.
Now I am planning  to change the layer 2 access layer and TOR switch to layer 3
Please advise regarding the configuration and where should i place the fw
6 Replies 6
balaji.bandi
First this required downtime  and  Service interruption
Choose whatever IGP ( i prefer OSPF)
Run OSPF n Core Switch
Bring back any gateway configured on FW for Server to Core Switch.
Configure each leg connected port from Core to Access and Core to tor Layer3 port with p2p IP
so IGP can take care of load share equally/
By the way, you did not mention Core is in VSS ? or Traditional Layer 3 deployment.
Some examples for reference :
https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Campus/routed-ex.html
BB
Hi @balaji.bandi
The core is  VSS.
what about TOR switches. If I change SVI to the  TOR switches  or CORE switches ?
If you Looking for TOR Switches to be Layer3 (moving from FW) then my suggestion is to convert them to a p2p interface and run the same OSPF, just like other access switches.
This suggestion is based on your requirement,  If you are using FW in the path for Lan network to reach DC (or TOR Switches) some kind of protection, then leaving gateway on FW makes sense. and leaving the TOR switches as Layer 2.
BB
https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Campus/VSS30dg/campusVSS_DG/VSS-dg_ch3.html#wpxref28659
Route Access connect to VSS, please read this Doc.
sorry for my little acknowledge.
Hi @balaji.bandi
If I  change TOR switches to layer 3, and  routing will be on the firewall,
is there any benefit?
If you change the TOR to Layer 3, I do not see any advantage FW as routing here, your next peer should routing for you.
Personally, that is the best i do in Layer 3 deployment.
BB
