design
elite2010
Level 3
Level 3
Hi ,
Is it ok the firewall failover link also connects through the core switch?
Does it require a switch between load balancer and firewall?
AS i don't have my own public  IP , I am using a load balancer in internet zone
What are the pros and cons for the above design
Please suggest a better design than the above
--> Is it ok the firewall failover link also connects through the core switch?
The following applies with regard to the failover link when you use a switch (as opposed to directly connecting the units with a cable):
If you use a switch, make sure there is no other device on the same network segment (broadcast domain or VLAN) as the failover interfaces of the ASA.
So, basically, put the failover link in a separate Vlan.
--> Obviously the load balancer must have a connection to both firewalls. Which load balancer do you have ? If you don't use a switch, you need to connect each firewall to a separate interface on the load balancer. If you use a switch, you only need one interface on the load balancer.
Hello
Looks okay to me, I assume fws are clustered/HA paring, it is recommended not to have direct connections between the fws (crossovers) and do use switch interconnects (fastest possible) for the FW paring to maintain the stateful information and perform the synchronisation.
Kind Regards
Paul
