determining the correct IOS for upgrading to SSH
Kevin Melton
Level 2
Level 2
Given the following sho ver off of one of our routers:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.3(5b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 16-Jan-04 02:17 by kellythw
Image text-base: 0x80008098, data-base: 0x819FCF8C
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
ODEC-Rocksprings uptime is 3 years, 29 weeks, 18 hours, 52 minutes
System restarted at 13:44:17 EST Thu Mar 23 2006
System image file is "flash:c2600-is-mz.123-5b.bin"
cisco 2621XM (MPC860P) processor (revision 0x200) with 94208K/4096K bytes of memory.
Processor board ID JAE08010C2W (941807279)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ISDN Basic Rate interface(s)
1 Channelized T1/PRI port(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
ODEC-Rocksprings#sho flash:
System flash directory:
File Length Name/status
1 17088140 c2600-is-mz.123-5b.bin
[17088204 bytes used, 15941940 available, 33030144 total]
What version of code would be suitable to replace this code and to implement SSH?
Will "c2600-ipbasek9-mz.124-25b.bin" work?
Thank You.
frattonfaithful
Check our Cisco's Software Advisor
Collin Clark
The k9 version of code includes crypto which SSH is a part of.
Hope that helps.
Yes, this ios should work. One simple way to identify this is the K9 character in the ios name.
The specified Ios will support ssh ver 2.0
