DHCP and NAT overload
opnineopnine
Hi all,
I have the following topology :
Router 3:
     DHCP and access to Internet
Switch
   Simple layer 2 with vlan 10
 Router 4:
    Gets ip from the DHCP but when I want to ping to the outside (8.8.8.8) i don't get any answer.
    If I ping the outside interface from the Router 3 I get an answer.
Thanks.
Hello
Rtr 3 interface connecting to the switch I am guessing is on a different subnet then it outside interface?
Rtr4 is acting as a host device, and as such that subnet it resides on needs to be natted to the outside world,
Please post you configuration and we can review
res
Paul
Kind Regards
Paul
Hello sir,
The R3 interface is:
DHCP#sh run int e0/1
Building configuration...
Current configuration : 120 bytes
interface Ethernet0/1
description Inside
no ip address
ip nat inside
ip nat enable
ip virtual-reassembly in
end
interface Ethernet0/1.10
encapsulation dot1Q 10
ip address 157.10.10.1 255.255.255.0
end
R4 will be a host but yes I have to nat it for the outside, the outside IP is 101.1.108.241
make sure your configs look like below:
Router_3
ip dhcp excluded-address 157.10.10.1
ip dhcp pool LAN
network 157.10.10.0 255.255.255.0
default-router 157.10.10.1
dns-server 8.8.8.8
interface Ethernet0/0
description outside
ip address 101.1.108.241
ip nat outside
description Inside
no ip address
ip nat inside
ip nat inside
ip nat inside source list 1 interface Ethernet0/0 overload
access-list 1 permit 157.10.10.0 0.0.0.255
Switch
switchport mode trunk
switchpprt mode access
switchport access vlan 10
Router_4
ip address dhcp
Hello
Georg's config look okay  - just like to state RTR1 would also require a static default route towards RTR2
rtr 1
ip route 0.0.0.0 0.0.0.0 fa0/0 101.1.108.242
res
Paul
Kind Regards
Paul
