dhcp doesn't work in vlan
judah8521
Hello everyone,
I am a beginner on routing and switching
I am experiencing a problem with dhcp.
Before I raise this topic, I did the following check.
The scenario is that I try to build a DHCP server in switch 3560 and create vlan, and sync vlan through vtp and also assign IP address to different vlan.
//vtp password is wms
  • if the access port are belongs to the desired vlan on L2 Switch
  • if the desired VLANs are present on L2 Switch
  • if the VLANs are allowed on trunk interface
  • if the SVI's are up on Multilayer Switch
  • and then fainally the DHCP pools
The problem still exists.
The weird thing is if I assign a static IP address to one of the PC and it works. Once I switch back to DHCP, it shows me DHCP failed APIPA is being used.
Is there something wrong with my configuration??
Please help me!! I would be very appreciated.  Thank you so much.
Here is the configuration :
-----------multilayer switch-----------------
ip dhcp excluded-address 10.0.0.161 10.0.0.191
ip dhcp pool reception
network 10.0.0.160 255.255.255.224
default-router 10.0.0.161
ip routing
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface Vlan1
no ip address
shutdown
interface Vlan300
mac-address 0060.70bd.0201
ip address 10.0.0.161 255.255.255.224
--------------------------- switch ---------------------------------------------
spanning-tree mode pvst
switchport access vlan 300
switchport mode access
interface FastEthernet0/4
interface FastEthernet0/5
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
--------------vtp status----------vtp status--------from switch ---
Switch(config)#do sh vtp status
VTP Version : 2
Configuration Revision : 2
Maximum VLANs supported locally : 255
Number of existing VLANs : 6
VTP Operating Mode : Client
--------------vlan-----------vlan---------------vlan----from switch-------
VLAN Name Status Ports
1 default active Fa0/11, Fa0/12, Fa0/13, Fa0/14
Fa0/15, Fa0/16, Fa0/17, Fa0/18
Fa0/19, Fa0/20, Fa0/21, Fa0/22
Fa0/23, Fa0/24, Gig0/2
300 reception active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
VTP Domain Name : wms
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0xCC 0xA5 0x10 0xE3 0x4F 0x33 0x68 0x0B
Configuration last modified by 0.0.0.0 at 3-1-93 00:04:30
amikat
While your dhcp pool configuration specifies the network 10.0.0.160 255.255.255.224 you have excluded the whole subnet range, ie. your dhcp server has no free address to offer. Will you please adjust.
Best regards,
Antonin
9 Replies 9
amikat
Best regards,
Antonin
First of all, thank you Amikat and Georg Pauwen.
You guys did help me a lot.
I am very appreciated.
AND.....
Sorry, I have another issue.
I connect the server direct to the multilayer switch that mentioned previously.
I set up the vlan 200 for server purpose, and I also set the VSI for vlan 200.
The problems was that before I changed the ports (connect to servers) into to trunk, I managed to build the connectivity (ports assigned to vlan 200). Once I changed the ports into trunk, they lose the connection, and i could pint the vlan 200 interface...
here is the configuration of multilayer switch
the server are connected through port 14-21
The IP address of each one is from 10.0.1.18-10.0.1.25
Basically, I just entered static IP address to server, and nothing else
For example : IP address: 10.0.1.18 subnet mask: 255.255.255.240 Default gateway:10.0.1.17
---------------------multilayer switch---------------
ip dhcp excluded-address 10.0.0.129
ip dhcp excluded-address 10.0.0.241
ip dhcp excluded-address 10.0.1.49
ip dhcp excluded-address 10.0.1.1
ip dhcp excluded-address 10.0.1.57
ip dhcp excluded-address 10.0.0.193
ip dhcp excluded-address 10.0.1.32
ip dhcp excluded-address 10.0.0.225
ip dhcp excluded-address 10.0.0.65
ip dhcp excluded-address 10.0.1.65
ip dhcp pool training
network 10.0.0.0 255.255.255.192
ip dhcp pool production
network 10.0.0.128 255.255.255.224
default-router 10.0.0.129
ip dhcp pool finance
network 10.0.0.240 255.255.255.240
default-router 10.0.0.241
ip dhcp pool management
network 10.0.1.48 255.255.255.248
default-router 10.0.1.49
ip dhcp pool design
network 10.0.1.0 255.255.255.240
default-router 10.0.1.1
ip dhcp pool order
network 10.0.1.56 255.255.255.248
default-router 10.0.1.57
ip dhcp pool research
network 10.0.0.192 255.255.255.224
default-router 10.0.0.193
ip dhcp pool testing
network 10.0.1.32 255.255.255.240
default-router 10.0.1.33
ip dhcp pool hr
network 10.0.0.224 255.255.255.240
default-router 10.0.0.225
ip dhcp pool wireless
network 10.0.0.64 255.255.255.192
default-router 10.0.0.65
ip dhcp pool conference
network 10.0.1.64 255.255.255.248
default-router 10.0.1.65
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
switchport access vlan 200
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
interface Vlan200
mac-address 0060.70bd.020e
ip address 10.0.1.17 255.255.255.240
interface Vlan300
interface Vlan400
mac-address 0060.70bd.0202
ip address 10.0.1.57 255.255.255.248
interface Vlan450
mac-address 0060.70bd.0203
ip address 10.0.1.33 255.255.255.240
interface Vlan500
mac-address 0060.70bd.0204
ip address 10.0.0.129 255.255.255.224
interface Vlan550
mac-address 0060.70bd.0205
ip address 10.0.1.1 255.255.255.240
interface Vlan600
mac-address 0060.70bd.0206
ip address 10.0.0.241 255.255.255.240
interface Vlan700
mac-address 0060.70bd.0207
ip address 10.0.0.225 255.255.255.240
interface Vlan750
mac-address 0060.70bd.0209
ip address 10.0.0.1 255.255.255.192
interface Vlan800
mac-address 0060.70bd.020a
ip address 10.0.1.49 255.255.255.248
interface Vlan830
mac-address 0060.70bd.020b
ip address 10.0.1.65 255.255.255.248
interface Vlan850
mac-address 0060.70bd.020c
ip address 10.0.0.193 255.255.255.224
interface Vlan950
mac-address 0060.70bd.020d
ip address 10.0.0.65 255.255.255.192
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
What was the reason for changing server ports from access to trunk? With trunk settings the Vlan 200 gets tagged which I doubt your servers would understand. What is wrong with the port settings as "switchport mode access" and "switchport access vlan 200"? What exactly are you trying to achieve?
Thanks & Regards,
Antonin
on a side note, for the port to work as trunk link to your server, you need to add 'switchport trunk native vlan 200' to the port configs:
I agree with the other posters...the question is why you would need a trunk link to start out with ?
To Amikat and Georg Pauwen
You guys are being very helpful. Thank you again.
The goal is to make other machines can communicate to those servers.  For example one is file server.
I thought if i just assign ports to vlan 200, the other machine cannot communicated to the machine ??
I did try only assign vlan 200 to the port, and the result is the server can ping to default gateway, but cannot ping to any of other machine.
OR
Maybe there is something wrong with my thought (on security purposes or common practice)??
Not quite sure if i need to achieve this goal with router and switch or should I implement it through the function of the server ???
In some cases (e.g. vmware servers) the trunk may be appropriate, but generally access ports are used for servers. For other boxes (stations) communication within different vlans your L3 switch can arrange via L3 switching (routing) using SVIs, ie. you can configure SVI for every vlan connected and assign its address for each vlan as DG. I hope this makes sense.
Best regards,
Antonin
To Amikat and Georg Pauwen,
I understood the concept now.
Finally, I did stick with access port and apply another ACL to block certain traffic in the experiment. I also know the concept of DMZ. The machines inside have to face public kind of directly. Another question just hit my brain. We know we need to use VALN to separate the traffic. However, do we assign the different range of IP address or VLAN to the servers in DMZ ??? such EMAIL, and WEB servers or just stick to the Server VLAN (if applicable )
DMZ servers are usually handled by a router or FW (ASA in Cisco world) not L3 inside switch.  While you could control the traffic to some extent with your L3 switch you cannot provide static NAT which is typically required. DMZ should be kept separate from the internal Vlans (including server Vlan).
Best regards,
Antonin
Good spot, Amikat !
To be on the safe side, I would also put 'spanning-tree portfast, on the access ports:
