DHCP Dual ISP on ASA 5506-X
sSiDs
Hi team! community forum delete my previous post concerbed it as "double post"...don know why)
My goal is to achieve auto switch to backup ISP YOTA if primary OUTSIDE goes down...
1. There are no static routes, does it correct?
2. ASA accept only one string with dhcpd auto_config OUTSIDE
if i put commant dhcpd auto_config YOTA, it;s overright previous OUTSIDE.
interface GigabitEthernet1/1
 nameif OUTSIDE
 security-level 0
 dhcp client route track 10
 ip address dhcp setroute
interface GigabitEthernet1/2
 nameif YOTA
 security-level 0
 dhcp client route distance 254
sla monitor 100
 type echo protocol ipIcmpEcho 8.8.4.4 interface OUTSIDE
 num-packets 5
 threshold 6000
 frequency 10
sla monitor schedule 100 life forever start-time now
track 10 rtr 100 reachability
dhcp-client client-id interface OUTSIDE
dhcp-client client-id interface YOTA
dhcpd address 192.168.22.100-192.168.22.200 INSIDE
dhcpd dns 1.1.1.1 208.67.222.222 interface INSIDE
dhcpd enable INSIDE
sSiDs
yeah, customer has bought static IP from ISP.
now SLA works like a charm)
thank you team for helpful advices.
6 Replies 6
sSiDs
off topic)
ssh version 2
just reload ASA and saw....why it sjows that i using v1?
Reading from flash...
!!!...WARNING: This command will not take effect until interface 'OUTSIDE' has been assigned an IPv4 address
WARNING:
SSH version 1 is not secure.
It is recommended that only SSH version 2 be used.
SSH version 1 support will be removed in a future release.
*** Output from config line 202, "ssh 0.0.0.0 0.0.0.0 OUTS..."
WARNING:
*** Output from config line 203, "ssh 0.0.0.0 0.0.0.0 INSI..."
WARNING: This command will not take effect until interface 'MGMT' has been assigned an IPv4 address
WARNING:
*** Output from config line 204, "ssh 0.0.0.0 0.0.0.0 MGMT"
WARNING: This command will not take effect until interface 'MGMT' has been assigned an IP address
*** Output from config line 209, "management-access MGMT"
sSiDs
ASA5506X# sh run | i ssh
aaa authentication ssh console LOCAL
ssh stricthostkeycheck
ssh 0.0.0.0 0.0.0.0 OUTSIDE
ssh 0.0.0.0 0.0.0.0 INSIDE
ssh timeout 40
ssh version 2
ssh key-exchange group dh-group14-sha1
ASA5506X#
ip address dhcp <-- meaning the ASA as DHCP client and in your case the dual ISP it have client for both outside and Yota
dhcpd enable INSIDE<--this make ASA as DHCP server for INSIDE client
dhcpd auto-config copy any parameter get from Server  "when the ASA as DHCP client" to when the ASA as DHCP Server.
ip address dhcp setroute<-- this command is config default route toward the GW you get from DHCP server "when the ASA as DHCP server".
Hello
Looks like you have it correct-
Example:
sla monitor 1
num-packets 3
frequency 10
sla monitor schedule 1 life forever start-time now
track 1 rtr 1 reachability
int gig1/1
interface gig1/2
Kind Regards
Paul
Hi Friend
I think I get what you want to achieve here,
the issue arise from your have dual ISP and each one have it DNS Server and dhcpd auto-config can apply for only one OUTSIDE "one ISP" so my suggest is config the DHCP primary and secondary for your client instead of using auto-config, where auto-config is filled when the one ISP link drop.
sSiDs
