09-28-2021 09:47 PM
EOL of ISR4331-B/K9 was announced in 2019.
but we are still utilizing ISR4331-DNA with IOS XE SDWAN enabled and HW looks same as ISR4331-B/K9.
There is no information regarding the difference between ISR4331-B/K9 and ISR4331-DNA.
Does anybody know the diff?
Solved! Go to Solution.
09-28-2021 10:14 PM
according to your EOL doc,
ISR4331-B/K9 is EOL announced. you can see exact HW model using
#show inventory
command and it will list the exact HW SKU. you need to check that for EOL.
if that says ISR4331-B/K9 as your model, then your router is EOL announced.
Good luck
KB
09-28-2021 10:14 PM
#show inventory
Good luck
KB
09-28-2021 11:20 PM
Show inventory result on our RT is, ISR4331-K9, so it`s different product.
Many thanks for help.
09-28-2021 11:36 PM
- For your own devices you can always use :
https://cway.cisco.com/sncheck/
M.
