DHCP exclusion not working
AHMADJ
i have two routers ra and rb with HSRP between them i have configured dhcp exclusion addresses but i am getting ip conflict ERROR MASSEGES BELOW details
Jul 15 2020 15:05:57.883 UAE: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 10.114.53.3.
Jul 15 2020 15:05:58.933 UAE: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 10.114.53.1.
Jul 15 2020 15:05:59.469 UAE: %IP-4-DUPADDR: Duplicate address 10.114.53.2 on GigabitEthernet0/0/1.20, sourced by 247e.12bf.4003
Jul 16 2020 10:59:58.270 UAE: %IP-4-DUPADDR: Duplicate address 10.114.53.2 on GigabitEthernet0/0/1.20, sourced by 247e.12bf.4003
Jul 16 2020 11:00:29.590 UAE: %IP-4-DUPADDR: Duplicate address 10.114.53.2 on GigabitEthernet0/0/1.20, sourced by 247e.12bf.4003
Jul 16 2020 12:02:37.889 UAE: %IP-4-DUPADDR: Duplicate address 10.114.53.2 on GigabitEthernet0/0/1.20, sourced by 247e.12bf.4003
IOS image :isr4300-universalk9.03.16.04b.S.155-3.Sn4b-ext.SPA.bin
Router RA
ip dhcp excluded-address 10.114.53.1 10.114.53.10
ip dhcp pool VOICE
network 10.114.53.0
default-router 10.114.53.1
dns-server 10.32.x.x
option 150 ip 10.32.x.x
interface GigabitEthernet0/0/1.20
description Branch Backup-VOICE VLAN 20
encapsulation dot1Q 20
ip address 10.114.53.3 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow monitor FLOW-MONITOR-1 input
ip flow monitor FLOW-MONITOR-1 output
standby 1 ip 10.114.53.1
standby 1 priority 110
standby 1 preempt
no cdp enable
h323-gateway voip interface
ip virtual-reassembly
RB#show ip dhcp binding
Bindings from all pools not associated with VRF:
IP address Client-ID/ Lease expiration Type State Interface
Hardware address/
User name
10.114.53.26 0100.59dc.5b9e.c9 Jul 21 2020 11:20 AM Automatic Active GigabitEthernet0/0/1.20
10.114.53.28 01b4.a8b9.e92d.47 Jul 21 2020 11:21 AM Automatic Active GigabitEthernet0/0/1.20
RB#show ip dhcp conflict
IP address Detection method Detection time VRF
10.114.53.5 Ping Jul 15 2020 03:06 PM
ROUTER-RB#show ip dhcp database
ROUTER-RB#show ip dhcp server statistics
Memory usage 18580
Address pools 1
Database agents 0
Automatic bindings 2
Manual bindings 0
Expired bindings 4
Malformed messages 20
Secure arp entries 0
Renew messages 123
Workspace timeouts 0
Static routes 0
Relay bindings 0
Relay bindings active 0
Relay bindings terminated 0
Relay bindings selecting 0
Message Received
BOOTREQUEST 0
DHCPDISCOVER 115
DHCPREQUEST 1890
DHCPDECLINE 2
DHCPRELEASE 1
DHCPINFORM 24
DHCPVENDOR 0
BOOTREPLY 0
DHCPOFFER 66
DHCPACK 303
DHCPNAK 0
Message Sent
BOOTREPLY 0
DHCPOFFER 34
DHCPACK 134
DHCPNAK 0
Message Forwarded
BOOTREQUEST 0
DHCPDISCOVER 68
DHCPREQUEST 315
DHCPDECLINE 2
DHCPRELEASE 0
DHCPINFORM 24
DHCPVENDOR 0
BOOTREPLY 0
DHCPOFFER 66
DHCPACK 303
DHCPNAK 0
DHCP-DPM Statistics
Offer notifications sent 0
Offer callbacks received 0
Classname requests sent 0
Classname callbacks received 0
ROUTER ra
ip dhcp pool VOICE
network 10.114.53.0 https://protect-eu.mimecast.com/s/F8ZOC0RNVSj4Dsow3cI?domain=255.255.255.0
domain-name sib.ae
description Branch Main-VOICE VLAN 20
ip address 10.114.53.2 https://protect-eu.mimecast.com/s/F8ZOC0RNVSj4Dsow3cI?domain=255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
standby 1 preempt
no cdp enable
h323-gateway voip bind srcaddr 10.114.53.2
ROUTER-RA#show ip dhcp binding
Hardware address/
User name
10.114.53.34 01b4.a8b9.e92c.6b Jul 21 2020 08:55 AM Automatic Active GigabitEthernet0/0/1.20
10.114.53.35 01c0.64e4.d994.0d Jul 21 2020 11:13 AM Automatic Active GigabitEthernet0/0/1.20
10.114.53.37 01b4.a8b9.e92d.3f Jul 21 2020 11:21 AM Automatic Active GigabitEthernet0/0/1.20
ROUTER-RA#show ip dhcp conflict
10.114.53.3 Ping Jul 15 2020 03:05 PM
10.114.53.1 Ping Jul 15 2020 03:05 PM
ROUTER-RA#show ip dhcp database
ROUTER-RA#show ip dhcp server statistics
Memory usage 19363
Address pools 1
Database agents 0
Automatic bindings 3
Manual bindings 0
Expired bindings 2
Renew messages 43
Static routes 0
Relay bindings 0
Message Received
BOOTREQUEST 0
DHCPDISCOVER 114
DHCPREQUEST 1763
DHCPDECLINE 2
DHCPRELEASE 0
DHCPINFORM 24
DHCPVENDOR 0
BOOTREPLY 0
DHCPOFFER 66
DHCPACK 312
DHCPNAK 0
Message Sent
BOOTREPLY 0
DHCPOFFER 23
DHCPACK 86
DHCPNAK 0
Message Forwarded
BOOTREQUEST 0
DHCPDISCOVER 67
DHCPREQUEST 315
DHCPDECLINE 2
DHCPRELEASE 0
DHCPINFORM 24
DHCPVENDOR 0
BOOTREPLY 0
DHCPOFFER 66
DHCPACK 312
DHCPNAK 0
DHCP-DPM Statistics
8 Replies 8
if you are sure that your HSRP enabled interfaces do not have duplicate IP addresses, try the interface command 'standby use-bia' in order to force the interfaces to not use the virtual MAC addresses...
i have the same dhcp pool  configured in both routers RA and RB and both have the same default gateway which is the  HSRP virtual  ip 10.114.53.1  ,if i apply command standby use-bia this will not make dhcp releases to be flapped and this will fix reserved dhcp ip and ip conflicts?belwo configration
standby 1 preempt
no cdp enable
ip address 10.114.53.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
standby 1 preempt
no cdp enable
all that command does is use the actual MAC address of the interface instead of the virtual MAC. It should not have any influence on any other DHCP lease...
As an alternative, you can also disable the entire DHCP ping operation:
Router(config)#ip dhcp ping packets 0
so the ip exclusion is working fine my issue could be with HSRP MAc addresses this making duplicate address? and
Hello
When you have a dhcp server running in both rtrs with the same scope without splitting that scope will cause duplication you need to make half the scope active on either server and exclude the other half
- on a side note both hsrp stanzas have the same hsrp priority value i would suggest you change this also
lastly how are the two rtrs interconnected?
Kind Regards
Paul
they are connected back to back gig0/1 ----->gi0/1 and hsrp is conigured under sub interface gig0/1.20
Hello
So if this a direct internal interconnected link not sure why you have netflow and disabling icmp unreachables is applied
 Do you have any other hsrp sub-interface active with dhcp
Have you checked the physical status of this interconnect?
Kind Regards
Paul
