DHCP in interVLAN routing
Kristi
I have this simple network with 1 core & 1 distribute switches, where I directly added PCs in a different VLANs to make sure that config was working, but VLANs on distribute switch can't get ping or DHCP IP. What's my issue here ?
Hello
Where is your dhcp server located?
I cannot open you PT file to check your configuration however i assume your core switch is performing the intervlan routing? - Make sure you have ip routing enabled on the core and disabled on the distribution switch, Do the clients receive dhcp allocation?
Kind Regards
Paul
hostname DistributeSwitch
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
no ip cef
no ipv6 cef
username admin secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
ip ssh version 2
no ip domain-lookup
ip domain-name cisco.com
spanning-tree mode pvst
interface GigabitEthernet1/0/1
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/2
switchport access vlan 40
switchport mode access
switchport port-security maximum 5
switchport port-security mac-address sticky
switchport port-security violation restrict
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
switchport access vlan 50
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface Vlan1
no ip address
shutdown
interface Vlan40
mac-address 000a.4161.8c01
no ip address
interface Vlan50
mac-address 000a.4161.8c02
no ip address
ip classless
ip flow-export version 9
banner motd ^CPrivate Use Only!^C
line con 0
password 7 0822455D0A16
login
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5
login local
transport input ssh
end
hostname CoreSW
ip dhcp pool VLAN10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8
ip dhcp pool VLAN20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 8.8.8.8
ip dhcp pool VLAN30
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
dns-server 8.8.8.8
ip dhcp pool VLAN40
network 192.168.40.0 255.255.255.0
default-router 192.168.40.1
dns-server 8.8.8.8
ip dhcp pool VLAN50
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
dns-server 8.8.8.8
no ip cef
no ipv6 cef
ip ssh version 2
no ip domain-lookup
switchport access vlan 10
switchport access vlan 20
Interface GigabitEthernet1/0/11
switchport access vlan 30
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0003.e42c.dd01
ip address 192.168.10.1 255.255.255.0
interface Vlan20
mac-address 0003.e42c.dd02
ip address 192.168.20.1 255.255.255.0
interface Vlan30
mac-address 0003.e42c.dd03
ip address 192.168.30.1 255.255.255.0
interface Vlan40
mac-address 0003.e42c.dd04
ip address 192.168.40.1 255.255.255.0
interface Vlan50
mac-address 0003.e42c.dd05
ip address 192.168.50.1 255.255.255.0
ip classless
line con 0
login
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5
login local
transport input ssh
end
This is the whole config there
I have opened your file, the config looks good, but the PCs in Vlans 40 and 50 don't get IP addresses. Out of curiosity, I have recreated your setup in version 7.2.1 of Packet Tracer, and it works just fine. I would suggest to download and install the latest version and open the file I attached. Packet Tracer is rather quirky, so it might just be a version problem...
