DHCP ip helper-address
helplesskheng
Hi, I am currently learning about DHCP and would like to know more.
I have the set up shown in the image with Router0 being the DHCP in this case. I have got PC4 and 5 in the same VLAN and there is a trunk from Switch1 to Switch2, likewise from Switch1 to Switch3.
I am unable to get an IP from both PC4 and 5, thus I have tried the DHCP ip helper-address at Switch1 and now PC3,6 and 7 cannot get an IP form the DHCP.
7 Replies 7
Richard Burts
You have given us a description of a problem but no detail about it to help us identify the issue and suggest solution. A good starting point would be to post the config of the router.
Rick
Sorry bout that!
Building configuration...
Current configuration : 1145 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip dhcp pool round1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
ip dhcp pool round2
network 192.168.2.0 255.255.255.0
default-router 192.168.2.254
ip dhcp pool vlan10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.254
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524XTVU-
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.1.254 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.254 255.255.255.0
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.10.254 255.255.255.0
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
if this is a Packet Tracer project, post the (zipped) .pkt file here...
If all links between the switches and the router are trunks, you don't need any ip helper-addresses. Just make sure that you exclude the default router IP addresses:
version 15.1
hostname Router
--> ip dhcp excluded-address 192.168.1.254
--> ip dhcp excluded-address 192.168.2.254
--> ip dhcp excluded-address 192.168.10.254
ip dhcp pool round1
ip dhcp pool round2
ip dhcp pool vlan10
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
I had changed a few things to make things simpler, but it is roughly still the same thing.
Also is trucking actually possible across routers to switch?
as suggested earlier, you need to set all inter-switch links and the uplinks to the router as trunks. Find attached the revised, working project file (you need PT version 7.3 to open it)...
Cristian Matei
     I understand that the DHCP server is the router, but the default gateway for the PC3 to PC7 will be switch1?
         -Make sure you configure on switch1 "ip helper address", on the SVI's corresponding to the vlan number for PC3 to PC7.
         -Make sure the DHCP router has a route back for all those subnets for which it's a DHCP server (the IP subnets of the PC's) towards SW1
         - Make sure the DHCP router has a separate DHCP pool for each of the VLAN's of PC3 to PC7
Cristian Matei.
Mlex1
in you situation packet tracer has a lot of bag, e recommend for use gns3 or vmware, upper colleges gives for you advice
Wish all the best
