DHCP Issue on VRF
Learnercisco
Hi Teck People
i am facing on strang issue in my Distribution 9600 if some body face this issue guide me please
IP phone is not getting IP Address from Cisco 96000 DHCP Server but Serve is showing the binding:
DHCP SERVER Binding:
Switch-1A#show ip dhcp binding
Bindings from all pools not associated with VRF:
IP address      Client-ID/              Lease expiration        Type       State      Interface
                Hardware address/
                User name
Bindings from VRF pool Telephone:
                Hardware address/
                User name
172.17.30.14    01a4.b239.4805.6f       Infinite                Automatic  Active     Vlan67
Switch-1A#
DHCP Server Confguration
ip dhcp use vrf connected
ip dhcp excluded-address vrf Telephone 172.17.30.1 172.17.30.2
ip dhcp pool TPH-67
vrf Telephone
network 172.17.30.0 255.255.255.0
default-router 172.17.30.1
option 150 instance 1 ip 172.17.50.5
option 150 instance 2 ip 172.17.50.6
lease infinite
ip dhcp snooping information option allow-untrusted
can somebody suggest
32 Replies 32
looking at the output below:
*Jul 14 08:49:32.159: DHCPD: Sending DHCPOFFER to client 01a4.b239.4805.6f (172.16.130.11).
and what you posted earlier:
interface Vlan67
vrf forwarding Telephone
ip address 172.16.30.1 255.255.255.0
check if you did not simply make a typo somewhere. The DHCP offer is for 172.16.130.11, while the Vlan interface has IP address 172.16.30.1, which is a different subnet.
Hello
@Learnercisco wrote:
Hi Teck People
I dont see any reference to any dhcp server in you configuration, either on the distribution or access switch so where is this server located also i don’t see any voice vlan appended to the switch access port for the phone? -switchport voice vlan x
Kind Regards
Paul
Hi George Thanks for your Support
we have two seprate cluster for Distribution.
Finally the issue solved by upgrading on the IOS of Distribution Swiitches
Platform C9606R
Presinstalled IOS version:16.12.02
Upgraded IOS version: 16.12.3a (This s a stable version )
Thanks for Support from Everyone.
