DHCP issue with windows 7 machines
zeuscyril
Level 4
Level 4
hi all,
i configured cisco 1841 router having the following c1841-ipbasek9-mz.124-24.T2.bin
i confiured DHCP server in this router,
but all the XP machines are getting the dhcp ip address but the windows 7 machines showing limited connectivity
my dhcp config,
ip dhcp pool DATA
   network 192.168.15.0 255.255.255.0
   default-router 192.168.15.1 255.255.255.0
   dns-server 213.42.20.20 195.229.241.222
   option 150 ip 192.168.15.1
plz give me the solution.
Tharak Abraham
Level 3
Level 3
Cyril,
1. Please check for the dhcp service in your Win 7 hosts.
2. Please disable any antivirus on the host and check the same.
happened to read that lot of ppl face this issue..-:)
hi
i checked both the things no response,
we need to change on cisco routerside like update IOS or any config changes
I really dont think so you need to do anything on the IOS !
Morover its working great for your other hosts right ?
Can we sniff or SPAN on the switch and see the frames/packets to and fro ?
Are you using a firewall in your internal network ?
I just googled this up and saw people facing similar problems.
Wierd and shame behaviour of microsoft boxes !
Chad Elder
try removing the subnet from default-router
